Phantom Check Engine Light (CEL)
Old May 11, 2010 | 09:34 PM
Scinner's Avatar
Scinner
1995 Ford F150 351W 4x4
Check engine light comes on after driving 1/4 to 2 miles. Truck can idle for an hour in the driveway and no issues. By the time I hit 2 miles, the CEL will come on, and KOEO.KOER checks pull only one fault, right side thermactor, that bs Ford emissions crap, got me an eliminator and cleared that out.
No vacuum leaks, good power, timing set at 10 degrees, everything I can think of.
Why does the truck have to move? If it were speed sensor, wouldnt the ABS light come on, because that is tied into the speed sensors?
Old May 12, 2010 | 10:40 AM
rla2005's Avatar
rla2005
Are you still getting codes since you installed this eliminator? What were the code numbers you got before?
Old May 12, 2010 | 10:53 AM
Scinner's Avatar
Scinner
dont remember, 161 maybe, it decoded out to Right Side Thermactor. No codes now...
Comnt8r
1983 - 2012 Ranger & B-Series
Aug 19, 2011 10:31 AM
or94ran
15
Aug 9, 2006 09:13 AM
doodad
Aug 24, 2005 10:10 PM
jdb1937
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 29, 2004 08:10 PM
explorerphobia
Oct 3, 2003 12:30 PM
