Dual Steering Stabilizer install question
Old May 11, 2010 | 07:58 PM
JDTDBD's Avatar
JDTDBD
The rough country kit says the passenger side bracket goes right onto the u bolts for the springs and is followed by the supplied torque nuts (2). The driver side says to remove existing nuts and add bracket and put existing nuts back on. The brackets are identical. Wont this make the kit sit lower on the passenger side? I asked Rough Country and they said no it will be even. They answered my question pretty quick (like 10 seconds) and I know they have a lot of different applications per each make and model year too. Unless they are just that knowledgeable about everything for every make and model.... I dunno.
My other problem was the 8" suspension kit on it now was def torqued too tight. I can't get the nuts off the bottom of the spring u bolts. I was thinking about buying 2 more 15mm torque nuts and adding the bracket on the driverside just like the passenger side (on top of the existing nuts) to me this seems level as this is all attached to the axle and that def should be level. I dunno, could use an outside opinion, thanks in advance
Old May 13, 2010 | 04:59 PM
JDTDBD's Avatar
JDTDBD
53 views and nothing? no one else has a dual set up that ran into any issues?
I guess I am gonna just get 2 more nuts put this set up together and check it with a level.
Old May 13, 2010 | 11:55 PM
jim6liter's Avatar
jim6liter
just put it on like the instructions say and see how it looks.If you don't like it,modify it!
Old May 14, 2010 | 12:11 AM
sarnott140's Avatar
sarnott140
you would have much better luck posting in the super duty forum
robert_l_ross
Sep 1, 2023 03:17 PM
Deiboe
Apr 19, 2013 06:09 AM
cowboybootlegger
53
Jul 17, 2012 12:43 PM
dale gribble
19
Nov 15, 2005 01:05 PM
fordman300
Offroad & 4x4
Jan 17, 2004 01:25 PM
