Fuel Pump Help!
Old May 11, 2010 | 10:11 AM
cjn3's Avatar
cjn3
Fuel Pump Help!
I have a 95 PSD I was sitting at a light and it started running real rough so I pulled off to the side and it died and would not re-start.I pulled the top of the filter housing off and no fuel.After I had it towed home I got on here and read around and tried a few things( I filled the filtr housing with fuel) I finaly got it to start.Before I filled the fitler housing with fuel I had someone turn it over while I put a tire gauge on it and it had no pressure.I put the fuel in it and after turning it over for a while it would not start, I found the screen on the side and pulled it out and it was full of junk, cleaned it out and that is when I finaly got it to start.It seem to run fine.I drove it around off and on for a couple of days(about 50 miles) then it did it again No fuel in the housing and the screen is clean.Is my fuel pump going out or could it be something else.Thanks for anyones help.
Old May 11, 2010 | 10:19 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Yeap, my money is in the fuel pump, surely is toast.
BTW welcome to the forum.
Old May 11, 2010 | 10:33 AM
cjn3's Avatar
cjn3
ROENTGEEP thanks
Old May 11, 2010 | 10:48 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
ROENTGEEP thanks
No problem. Im sure somebody else will chime in here soon. Good luck.
Old May 11, 2010 | 01:25 PM
rideracelivemx7's Avatar
rideracelivemx7
very interesting how it died then came back.. but its not electrical or anything so you know it has to be it, go to advance autoparts, they have a lifetime warranty on theres, i belive 130$
Old May 11, 2010 | 03:46 PM
pjwoolw's Avatar
pjwoolw
Look here for a kit that has most everything you will need.
Old May 11, 2010 | 11:48 PM
Jacksfirstdiesel's Avatar
Jacksfirstdiesel
Man! that looks like a great kit PJ. I did mine in bits and pieces. That would have saved a lot of time!
CJN3 welcome! If you search on fuel pump in this page there is a couple tricks you will find to changing out your pump.
