return line?
Old May 11, 2010 | 09:07 AM
srqdiesel chef's Avatar
srqdiesel chef
return line?
is it possible for the return lines to drain into the tank that is not switched on? I filled up my back tank and now it's below half and the front tank is full after 3 days and maybe 50 miles. So, I'm thinking when I run on the back tank the return lines are draining into the front tank. Is that possible? and if it is, how do I fix it? I had this happen a few weeks back and thought I was just being a tool and had forgotten which tank I had it on, but here we go again.
Old May 11, 2010 | 09:16 AM
farmert's Avatar
farmert
Sounds like the fuel selector valve is crapping out. That is the olny place fuel could return to a different tank.
Old May 11, 2010 | 01:32 PM
PLC7.3's Avatar
PLC7.3
When the FSV switches it should go ZZIIPP at that point the fuel level contacts and redirection of the valve should be complete. The completed operation is indicated by the new fuel level. IF the fuel is going to the wrong tank then the valve is fubar. Do not discount a bad connector or wires so check them.
NWVintage
Dec 25, 2013 04:56 PM
pmooney
Dec 4, 2011 05:45 PM
tootall5764
Feb 18, 2011 09:13 PM
jrwhitey_2000
Jan 20, 2008 08:56 AM
