I have a kick a$$ electronics store up here near me so if anyone needs these or any other resistors or parts that you can't find, let me know and I can hook you up.
Is there a write up to show the dummies like me, how to and where to instsll this resisor. Thanks
You just install it across the 2 wires of the EBPV to eliminate the soft code. Stuff it right into the connector if you want. Also works for the AIH.
Roland I thought it was you that was burning up 1/2watters... guess I was wrong. I'll take the change I removed from the center console last night and pick up a pack of 1/2watters on my way to soccer practice tonight.
Check out the pic in this post by mueckster https://www.ford-trucks.com/forums/9...ml#post8790682. You bend the ends like he did and shove it into the plug. The plug you put the resistor in the one that plugs into the front of the pedestal.
Reason: needed to add to post
