Lowered F250 with 20 or 22's
No blocks between the axle and the springs, missing lug nuts? I wonder how the previous owner lowered the front end?
I hope you got a good deal on that ride, you may have purchased yourself a money pit.
I like the stance of your truck undrtw. My truck is a 01 F250 Crew Cab 2wd. Have a set of 22x9.5 ordered with a 5.93 BS and a set of 305/45/22 to go with them. The back needs about 4 inches to come down to be level with the front. It does have a block between the spring and the axle from memory. Truck is at a body shop having some paint work done so I don't know how large the block is. Any body know how much it will drop pulling the block?
On a 250 with the stock block it will drop it 2" or so.
On edit: Got beaten
Bill is right it may affect your driveline angle and cause vibration on accel with an excessive U-Joint angle if its a 2 piece shaft (being a crew cab it will be a 2 piece)
If your carrier bearing has shims, you can remove them to fix.
On edit: Got beaten
And due to your initial request not to bash, that's all I'll say about that!
#28
I understand everybody's point that's why I said the "no bashing", to each there own and blah blah, but I could make the same argument about people lifting there trucks up (which I have done) and so on. Just looking for info. I don't pull horses or work construction, the heaviest thing I pull is a Jeep crawler/trail rig. Thanks for eveybody's responses and if any one else has any more insight on my questioning or links to they would greatly be appreciated.
#29
#30
The screen on my laptop is small, but are you missing a few lug nuts?
It's an f350, not sure about shims, shackles or the front. It was a fair price. The Magna Charger, Wheels, & Sound system cost the previous owner close to what I paid for the truck. It runs like a bat out of hell with no mechanical issues... yet.
Haters be patient. I'm looking at lifting it after I unload my Jeep and kill these tires.
curtis
