302 ho need help
Old May 10, 2010 | 01:44 PM
jg6250's Avatar
jg6250
302 ho need help
I've got an 88 bronco W/ a motorsport 302 ho. Its got world product windsor jr. heads, headers,maf conversion MSD ign. roller rockers and a E-303 cam. Ever since the cam has been installed i've had idle issues. I've been to other forums and have heard others having the same prob W/ no solutions. I have even tried adv. cam timing W/ no luck. Any feed back on this cam? Does the PCM reject this cam? Need help getting frustrated !
Old May 10, 2010 | 02:50 PM
Conanski's Avatar
Conanski
Yeah that's what that cam does.. lopes and chugs and stuff, there is no fix for it short of replacing it with something else.
Old May 11, 2010 | 12:53 PM
jg6250's Avatar
jg6250
Lopes and chugs and stuff ??? Reaaally informative. The mustang guys have the answer. If anyone is interested the throttle body has to be drilled and the tps adjusted.
Old May 11, 2010 | 04:35 PM
Conanski's Avatar
Conanski
WTF!!!.. Please ban this *******.
Old May 11, 2010 | 05:30 PM
mudrnnr79's Avatar
mudrnnr79
Wow you just jumped right into being a jerk! You haven't been in the real world long have you?
Old May 11, 2010 | 06:32 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
...I've had idle issues??? Reaaally informative.
Nothing says "I have no desire to actually fix the problem in a way that doesn't create other issues" like drilling holes in throttle plates.
Old May 11, 2010 | 09:13 PM
fordeverpower's Avatar
fordeverpower
yeah, Conanski, while I don't agree with everything he says, has helped more punks than he should. You can not cam a fuel injected like carb, they usually need relative wide lobe seperation angles for increased vac and idle quality.
Old May 12, 2010 | 12:18 PM
lew52's Avatar
lew52
I run the E 303 cam with 1.72 rockers , with no problems , a little rough idle , but that comes with the territory....Lew
Old May 12, 2010 | 12:55 PM
jg6250's Avatar
jg6250
Thanks lew52 for the feed back. I already set my cam timing @ 2 degrees adv. and drilled the TB butterflies out to 11/64. Amazing difference at idle. Much more power at all rpm especially down low.
Old May 12, 2010 | 07:09 PM
BaronVonAutomatc
You'd probably be better off running the cam straight up and advancing ignition timing to ~14 degrees, but as long as it works no worries. You might try dialing in more timing anyway.
What rpm is it idling with the holes in the throttle plates, just out of curiosity?
Old May 13, 2010 | 10:51 AM
jg6250's Avatar
jg6250
Idle is @ about 1200 rpm still have to tweak ign timing and idle speed. After that I will start doing test and tune. Will post after that
Old May 13, 2010 | 11:13 AM
lew52's Avatar
lew52
I run my cam straight up , it idles at 1000 rpm in drive , but my truck has been tuned with a custom chip that was burned on the dyno ....Lew
