Speedometer half off
Old May 10, 2010 | 10:13 AM
redhawk41's Avatar
redhawk41
My speedometer in a 76 Crewcab showes about 40 to 50 at 70 mph. It is not consistant at all it varies by about 10 mph when GPS says 70. Also the needle bounces about 2mph all the time. Does anyone have an idea on what is wrong
Old May 10, 2010 | 03:56 PM
Hickfied's Avatar
Hickfied
It is off that much most likely because the truck has been re-geared. The needle bounces most likely because the speedo gear in the transmission is wore.
Getting a new speedo gear with the right amount of teeth should fix your problem, but which one, I do not know.
Old May 10, 2010 | 04:32 PM
jim collins's Avatar
jim collins
What is the rear gear ratio and how tall are your tires ? The needle doesent sound like it is to bad, but a worn out speedometer head will make the needle bounce around as well as not give the correct M.P.H. I would do as suggested and check the gear in the transmission first . A bad cable will make the needle bounce too . Jim
Old May 10, 2010 | 06:11 PM
redhawk41's Avatar
redhawk41
The rear end is 3.73s and the tires are 265/75/16s. The truck was regeared from 4.10s but it didn't change the speedo that much years ago (15) when the it was geared different. And what throws me is that the speedo isn't consistant. It will be around 40 one day and then 50 the next when GPS says 70.
moneypit79
Apr 14, 2013 04:26 PM
fixitman1310
Feb 24, 2010 05:16 AM
buttermilk
1983 - 2012 Ranger & B-Series
Mar 30, 2009 09:54 AM
jonnyrocket_70
Aug 21, 2004 06:46 PM
bigcmv
Feb 2, 2001 02:34 PM
