Coolant Loss
Old May 24, 2010 | 07:25 PM
Young Gun's Avatar
Young Gun
If your gonna upgrade te EGR cooler now is the time to do it since the tech will be in there.
Old May 25, 2010 | 11:07 AM
lawnboy1965's Avatar
lawnboy1965
So the mechanic called me today and said that he is having a hard time figuring out if I have the 18mm or 20mm dowels. He doesnt want to order the wrong parts. I figured that since I have an 07 they would be 20mm but he said some do and some dont, therefore we are in a predicament. I say order both and send the ones back that he doesnt use but ford doesnt see it that way I guess. Hopefully he gets all his research done in time to get the parts here by the end of the week and get my truck in on Monday. X (thats for I'm keeping my fingers crossed).
Old May 25, 2010 | 01:57 PM
npccpartsman's Avatar
npccpartsman
He has the truck and a VIN. What more does he need??? If he has the truck torn down he can measure---it's not rocket science--LOL.
Old May 25, 2010 | 02:47 PM
lawnboy1965
He figured it out. If you have the non flexable oil return tube on the turbo and the one piece intake tube from the air cleaner to the turbo you have the 20mm dowels, I have the 20mm dowels.
Old May 25, 2010 | 09:58 PM
texans's Avatar
texans
Umm. I don't think that's right as I have both of them and 18 mm dowls.
Old May 26, 2010 | 07:09 AM
lawnboy1965
I hope he is right, I dont want my truck down for waiting on parts, that would **** me off. My friends 06 doesnt have either. Course your build date could be after his and before mine also. I guess I will find out forsure next week when its tore down. Will it hurt to cut the scoop out of my up pipe while its apart?
Old May 26, 2010 | 11:30 AM
texans's Avatar
texans
I don't see how it would hurt.
Old Jun 4, 2010 | 02:59 PM
lawnboy1965
Truck goes under the knife on Monday, here is a list of what the mechanic is going to change: Head gaskets, EGR cooler, Oil cooler, STC Fitting and add ARP studs. Should be done by next Friday, as long as nothing goes wrong. I hope my luck changes and this doesnt ever happen again.
Old Jun 9, 2010 | 12:06 PM
lawnboy1965
Here is what my truck looks like at the moment.
Old Jun 9, 2010 | 02:10 PM
texans's Avatar
texans
Sweet. So what did he find out on the dowls.
Old Jun 10, 2010 | 07:20 AM
lawnboy1965
They were the 20mm ones. I checked it out last night since he had the heads off yet and low and behold the gaskets were blown. I had a feeling that the 2 radiator caps and the degas bottle would not fix it. At least its getting done right now. I watched him straight edge my heads and there was one spot on both heads that he could squeeze 1½ thousands feeler gauge under but not all the way through, it was no where near where the gaskets blew. The heads are back on and the oil cooler and STC fitting get changed today. Then the daunting task of putting it all back together.
Old Jun 10, 2010 | 07:28 AM
texans's Avatar
texans
So he did machine the heads then right?
Old Jun 10, 2010 | 07:55 AM
  #28
lawnboy1965
No, he did not cause it says up to 3 thousands, I hope that doesn hurt, what do you think. I posted some pics of the gaskets and other things. I guess I should say that the 1½ thousands wouldnt go under the straight edge, it would try to lift it and the 1 thousands would go under in one spot but not around the piston area.
Old Jun 10, 2010 | 07:58 AM
  #29
texans's Avatar
texans
I dont know the specs, but if you ask me I would want the heads to be perfectly flat. If not you run the risk of hg failure again.
Old Jun 10, 2010 | 08:07 AM
  #30
lawnboy1965
Just got off the phone with the mechanic, he is absolutely confident they will be fine. He said 1 thousands isnt enough to do even worry about. He said if they were 2 thousands he would have had them machined. Hopefully my confidence in my mechanic is true, and I am sure it is, since he also owns a 6.0.
