1978 - 1996 Big Bronco
Trans Swap
Old May 10, 2010 | 07:18 AM
lilrebel64095's Avatar
lilrebel64095
Trans Swap
79 Bronco with the 400 engine. right now it has the c6. im lookin to put a fmx trans in there. what will i have to worry about? can i just take the tailshaft housing of the fmx and bolt up the transfer case?
Old May 10, 2010 | 10:25 AM
Kemicalburns's Avatar
Kemicalburns
isnt the FMX a car tranny? what are you trying to gain by going this route. why not put in another C6. they are bullet proof and cheap to rebuild.
Old May 10, 2010 | 11:09 AM
lilrebel64095
not trying to gain anything by it. dont know anything about the FMX tranny, not sure if they ever put it in any trucks or not, just the fact that the C6 went out and a friend of mine has a FMX i can buy from him cheap but didnt know if it will work going into a truck.
Old May 10, 2010 | 11:12 AM
jas88's Avatar
jas88
Your main concern should be what engine the FMX came off of. You gotta have the correct bellhousing to bolt up to your 400. Most of the FMX's were behind 302s and 351Cs which won't have the same bellhousing pattern. You need one that was behind a 351M.
Old May 10, 2010 | 12:28 PM
lilrebel64095
it is still attatched to a 351M im just concerned with the transfer case bolting up to it?
Old May 10, 2010 | 08:49 PM
greystreak92's Avatar
greystreak92
The FMX never found its way into a 4WD truck so the likelihood of finding one with a t-case adapter tail-housing will be um, lets say... difficult. The C6 was followed by the AOD which is a derivative of the old FMX unit. I don't know if the AOD is similar enough that you could swap tail-housings from one to an FMX.
Old May 11, 2010 | 06:56 AM
lilrebel64095
thats what i was afraid of, i dont know much about the FMX but do know i have never heard of them being in trucks. thanks for the info guys.
Old May 11, 2010 | 12:02 PM
driverreturnonfoot's Avatar
driverreturnonfoot
I tried the swap once from my 78 T-bird to my Bronco just one problem after another not worth the mess. If the 4WD is good a rebuild on a C6 at most $1300. I had my tranny and 4WD system done at Aamco for $2200.
Old May 11, 2010 | 04:02 PM
jas88's Avatar
jas88
The 79 Bronco has a divorced xfer case, doesn't it?
