1978 - 1996 Big Bronco
Bad Starts!
Old May 9, 2010 | 08:42 PM
jimford1's Avatar
jimford1
Bad Starts!
Hey guys my 89 bronco 302efi starts up after like 6-8 cranks idles high like it should but then will lower idle and stall. When it is warmed up its fine. Any clus as to why it acts like this?? Thanks guys!!
Old May 10, 2010 | 08:21 PM
greystreak92's Avatar
greystreak92
Pull codes.... run KOEO and KOER tests and see what codes come back. Anything that is bad enough to cause the engine to stall will trigger a fault code. From there you can better troubleshoot. From where you are, you could chase this problem for days and dollars without success. Make sure you run the KOER test with the engine fully warmed.
