360 vs 390
Old May 9, 2010 | 02:12 PM
FordmanShane's Avatar
FordmanShane
360 vs 390
what's the pros and cons they are both great engines, ive got a 360 right now and im just wondering if i should stay with it..
ill be doing a-lot of trails, mud drag and just strait mud with a some street..
what do you think?
Old May 9, 2010 | 07:00 PM
Bear 45/70's Avatar
Bear 45/70
The basic rule of performance is;
"There is no replacement for displacement."
The longer stroke of the 390 means more torque and horsepower the the same set up.
Old May 9, 2010 | 10:58 PM
OrangeJuice's Avatar
OrangeJuice
Go with the 390, it wins hands down. I went from a 360 to a built-up 402, a 390 .060 over and never looked back.
OJ
Old May 10, 2010 | 01:12 PM
FordmanShane
OJ
402 does sound good, any overheating issues? i went electric fan on the 360 since the shroud was missing..
what's your carb cfm? good response?
Old May 10, 2010 | 01:48 PM
OrangeJuice
I don't have any overheating issues and I'm running a Derale 16'' Tornado electric fan. I'm running an Edelbrock 1411 750 CFM carb that has been rejetted and has really good throttle response. I like my set-up.
OJ
Old May 11, 2010 | 08:31 PM
fordeverpower's Avatar
fordeverpower
go 390, some people spend $1000 for a stroker and theres no need when you start with a 390. Some people crack me up with the 302 to 347 stroker, when they can use a 351w, space and weight are different stories.
Old May 12, 2010 | 10:32 PM
FordmanShane
good point, maybe a 390 with some good cylinder heads might be the best combo..
Old May 14, 2010 | 09:20 AM
TXstroker01's Avatar
TXstroker01
If both were sitting on the shelf for the same price, there's no reason not to choose the 390. If you're thinking of doing a build-up, then it would depend on your budget (i.e. if you just want to freshen-up your 360 and add a few bolt-ons versus starting over with a new block or swapping in crank/rods/pistons into your current 360 block). It will really depend on your goals, etc. FWIW, I currently run the 360 stocker in my '69 F-100, and it's getting a built 390 very shortly.
Old May 14, 2010 | 01:45 PM
Rockstone's Avatar
Rockstone
All things being unequal, I'd go for the 390.
Old May 19, 2010 | 08:49 PM
Cyclone_416's Avatar
Cyclone_416
Definately 390. But I guess it just depends on what your goals are, how much performance you want and can later add, and how much you want to spend. Judging from what you said your planning on doing, I think you will be a lot happier with the 390.
Old May 20, 2010 | 12:38 AM
FordmanShane
well alright then, seems like theres a big difference that im missing out on between the 2...what's the score 0 to 6
why would ford stuff a 360 in a f250 anyway, did the 360 only have a lower torque peak??? BTW when i was tearing down the front end of my truck i seen the cylinder head casting i was surprised to see D2TE-AA heads.
I would like to port these out to 2.09 intakes and 1.65 exhaust,
after i clean these head up. if anyone has any experience on porting these please share
i dont have any candidates to practice on and i know there's a certain technique on porting i just haven't got that far yet..
Old May 26, 2010 | 10:09 PM
Cyclone_416
I'll bet many people have wondered why ford put the 360 in the F250's. I believe they put the 390 in some of them. My old 76 F250 2wd had a factory 4V 390. My only guess is that maybe the 360 lugged a lil better but that's probably marginal at best and just a guess.
Old May 26, 2010 | 10:31 PM
Bear 45/70's Avatar
Bear 45/70
I've had both in the same truck and the 360 doesn't come close to the 390 in any area.
Old May 26, 2010 | 10:39 PM
Cyclone_416
Were they both stock Bear?
Old May 26, 2010 | 11:14 PM
Bear 45/70's Avatar
Bear 45/70
The 360 was stock as was the 390 was, both were also 2 barrels. The second 390 was my creation, a 9 to 1 compression 390 with 390GT heads and intake with a GT carb reworked, by me. There was a recurved dist (me again), a mild RV cam, 256° with .525" of lift at the valve and GT exhaust manifolds (a real bitch to make fit) with a 2 1/4" dual exhaust with a crossover. A 3 engines were up run in my old 1968 F250 with a C6 and 3.73 gears with stock tires. The stock 390 not only out pulled the 360 but would mpg better. My engine build would out pull the guys running 460s even. Run over the 5,000 foot mountain passes with the camper in the truck and the race boat in tow and do it in high gear. The stock 390 require 2nd gear as did the 360 but it was on the floor a lot sooner.
The numbers on the stock engines tells the whole story.
360 - 215 hp @ 4400 and 327 ft/lbs @ 2400
390 - 255 hp @ 4400 and 376 ft/lbs @ 2600
Beside the 30 extra cubic inches the horsepower and torque numbers are better.
steve33444
106
Nov 30, 2020 10:37 AM
Hessmonster
Nov 28, 2016 08:32 AM
mudstepper
34
Jul 15, 2007 03:50 PM
YoungMT Hick
18
Jun 24, 2007 06:13 AM
MBBFord
Offroad & 4x4
20
Jul 23, 2005 09:54 AM
