voltage regulator
Old May 9, 2010 | 08:05 AM
cookieman69's Avatar
cookieman69
voltage regulator
Hello, How do you tell if alterntor has built in voltage regulator bought motor without truck so can't tell about wiring to v/r 1978 f100 302 carb Thanks Mike
Old May 9, 2010 | 02:17 PM
bkohne1's Avatar
bkohne1
What vehicle and what motor do you have?
Old May 9, 2010 | 02:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There were no alternators with the 'built in' regulator available until 1983.
1973/1982: Even if the engine is missing, the regulator should be mounted on the right fender inner apron adjacent to the starter solenoid.
Old May 9, 2010 | 07:45 PM
cookieman69
I bought motor out of truck that seller said was 1978 f100 302 I need wiring diagram for alternator voltage regulator Thanks Mike
buttwheat
Sep 29, 2013 10:13 AM
propman130
Oct 5, 2012 11:15 AM
bronco2ok
Bronco II
Feb 20, 2004 03:57 PM
bronco2ok
1983 - 2012 Ranger & B-Series
Feb 20, 2004 03:46 PM
cubster
Oct 11, 2001 10:35 PM
