old school overdrive
Old May 8, 2010 | 09:42 PM
skidoo440's Avatar
skidoo440
Looking to install an old style 5 speed in my 78 F-150 4x4. Like the old F-600/700 type. IE: CLARK,SPICER ETC. Truck has 400 motor. Any thoughts ? THANKS FOR ANY INPUT !
Old May 8, 2010 | 11:30 PM
Bowtie_Schmowtie's Avatar
Bowtie_Schmowtie
Most of the five speeds in gas powered medium duty trucks (if not all) are directs, not overdrives.
They are also much heavier and much larger, have larger yokes, and will require some reinforcing/ fabbing of the trans crossmember. I have a Fuller five speed direct in my '62 International, and it is at least twice as big as an NP435. It also tips the scales at over 400 pounds.
Your gains would be slim to nil in exchange for all that work and expense. I suppose theoretically that you could use one from behind a 370 or 429, as they have the same bellhousing pattern. If I was going to attempt a swap like this, I'd take the engine and trans as a unit and swap them both in. That way I could be assured that everything fit and worked together properly rather than hunting all over creation for parts that may or may not exist. The bellhousing itself would probably not fit in our pickup frames without extensive modification. Not to mention matching up clutch parts, linkages, hydraulics, etc.
But that's just me. I think you'd be much better off finding a ZF 5 speed from behind a 460 rather than messing with this idea. The ZF is a popular swap and there is a lot of info and support on this forum for it.
Old May 9, 2010 | 10:39 AM
PrairieF100's Avatar
PrairieF100
Years ago the father of a friend of mine put a 6031 spicer auxiliary transmission behind the stock 4 spd. in a 2 WD GM 3/4 ton he had. I was working at an International Harvestor dealership at the time and ordered him the remote shifter tower and a bunch of other small stuff to complete the install. He used an extra crossmember from another GM truck and when he was done it looked pretty close to a factory install. It wasn't cheap at that time because he had to make up two driveshafts plus all the other fabrication. One driveshaft went between the main and auxiliary transmissions and the second one had to be shortened between the auxiliary transmission and the differential. He also had to make the remote shifter linkage to the auxiliary transmission as well. I don't think he did it to improve mileage, but he did it to have more gear selection because of hauling a large fifth wheel trailer. If I remember the 6031 was also a 1.00 direct in third. The people at the GM dealership where he bought the truck thought he was crazy. But it worked and this modification was still in the truck when he sold it many years later.
Old May 12, 2010 | 10:00 PM
skidoo440's Avatar
skidoo440
THANKS FOR THE INPUT. JEFF
81f-150
Feb 22, 2016 10:04 PM
F250racer
Large Truck
Feb 12, 2015 05:56 PM
walt460
Feb 1, 2015 04:17 PM
ih781000
Dec 11, 2002 03:51 PM
