Overheating problem
Old May 8, 2010 | 08:59 PM
cabloom300's Avatar
cabloom300
Overheating problem
Mt brother just got a 91 F150 with a 300 and it has 268,000 miles on it. We put a new thermostat in it and hoses and we cant seemed to fix the problem. After the first time after the thermo was replaced it didnt overheat now its overheating again. do you think theres a block of water somewhere along the line or is it the water pump or radiator? Any suggestions?
Old May 9, 2010 | 06:41 AM
lew52's Avatar
lew52
Put a pressure tester on it & check for leaks & see if it holds pressure , with the radiator cap off when the motor is up to temp the thermostate should open & you should see circulation ...if not it could be thermostate , waterpump , cloged radiator ...Lew
Old Jun 18, 2011 | 08:21 PM
sreichel1's Avatar
sreichel1
overheat
I once had a mustang that kept overheating. It was the inside of a radiator hose that had collapsed. It looked fine on the outside.
steve
akf150-300
Apr 27, 2014 11:46 AM
3ahuss
Jul 10, 2013 03:28 PM
jdcpjc
Jul 7, 2012 03:32 PM
kevinred410
18
Aug 4, 2011 12:36 PM
rr41mag
Mar 5, 2011 08:52 AM
