Using 8 v battery
Old Jul 1, 2011 | 07:28 AM
jameszeesmith's Avatar
jameszeesmith
Using 8 v battery
Hello,
48 F-3, 6 cyl engine
I was thinking about using a 8 volt battery to replace my 6 volt. Since my rebuild of the original 226 6- cyl, the engine seems tight and doesn't crank easily. My battery guy said try an 8 volt? Any thoughts about this? Can I tweak the volt regulator to output enought voltage to charge the 8 volt battery. Will this burn out anything?
Better solutions...12volt/6 volt hybrid?
Thanks guys, my first post
Old Jul 1, 2011 | 09:33 AM
tinman52's Avatar
tinman52
Welder User
If you are going to buy a battery, get a GOOD 6 volt battery. They are available up to about 900 cold cranking amps. 8V batteries are a waste of money, IMO...
You may want to check the condition of your starter, batt cables and ground straps. Cables need to be large and grounds need to be many. Starter drag is usually what causes slow cranking, IMO....
My flathead v8 is fairly tight still, and starts easily with a 6V battery....
Again, only my opinion...
Also, WELCOME TO THE FORUM!!!!!!
Old Jul 1, 2011 | 04:04 PM
fking1's Avatar
fking1
tI had an 8 volt in my 55 6 volt system for a while. The regulator needs to be set up to charge 8. Could never get the 8 volts from the reg and eventually the bat died.
Went back to a 6 volt and it works fine.
Old Jul 1, 2011 | 04:29 PM
raytasch's Avatar
raytasch
Believe Nothing
Make certain you have big ol' heavy duty battery cables, heavy enough to carry the amperage for six volts. I've seen folks go to the auto parts store and get a light weight cable, about half the size of one needed for six volts and then wonder why the machine would not start. You need at least #2 cables with clean tight ends....., a good working starter and a good battery.
Old Jul 1, 2011 | 04:51 PM
38 coupe's Avatar
38 coupe
I've never seen good results with an 8V battery. Take off the batter cable connections, clean them, and snug them back down. Make sure your grounds are not loose. Make sure the jam nut on the copper stud on the starter is not loose. If everything is good and tight 6V works great. I prefer #1 cable size for 6V.
Old Jul 1, 2011 | 07:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
What do you do for light bulbs with an 8v system? (buy lots of them, I'd guess!)
beckman
19
Mar 13, 2022 06:54 AM
tom1940
Sep 17, 2014 08:00 PM
jhaas63
May 15, 2013 01:01 AM
agronomistont
Aug 3, 2011 06:43 PM
kc05
Oct 26, 2004 09:54 AM
