PCM FUBAR?
Old May 8, 2010 | 07:15 PM
superduty4x4's Avatar
superduty4x4
PCM FUBAR?
Yesterday I was killing some time and messing around with the truck and I decided to pull the kick panel to see how hard it is to get to the PCM from inside the cab. When I pulled the kick panel off I noticed the plastic plug that covers where you would install a chip was missing, which had me thinking WTF... PO said it had never been chipped. I decided to pull the PCM out to see if the wax coating was still over the contacts and it was for the most part but a few of the contacts have been scraped a little bit. I'm hoping they weren't scraped so deep that I'll have to get them re-tinned. I also noticed a little bit of rust between the bottom of the PCM and the metal case it rides in, which means water has been getting in the cab around the PCM... no bueno. The only evidence that the PCM has been messed with at all is a sticker under the hood saying it was re-flashed in 97, but I believe that is done thru the OBD2 port. Check out the pics and let me know what you think.
Old May 8, 2010 | 08:09 PM
Brown Falcon's Avatar
Brown Falcon
The contacts aren't TOO bad, but those two in the middle and one towards the left may need re-tinning.
Not sure what to tell you about the rust. And I dont' know how they do the re-flash.
Old May 8, 2010 | 08:17 PM
pjwoolw's Avatar
pjwoolw
Probably the dealer either messed with it or replaced the PCM and flashed it.
CSIPSD
29
May 21, 2012 07:16 PM
superduty4x4
16
Aug 23, 2011 10:23 AM
superduty4x4
44
May 20, 2011 09:53 AM
superduty4x4
21
May 9, 2011 11:00 PM
02puffer
All Things Towing
32
Mar 6, 2009 11:51 AM
