Re-gear ?,?,?
Old May 14, 2010 | 02:18 PM
cowmilker08's Avatar
cowmilker08
That's what I thought, which is why I was wondering if you could just swap the differential housings.
Old May 14, 2010 | 02:33 PM
93f1505.0L's Avatar
93f1505.0L
I hate to ster it up even more but I am pretty sure a 10.5 ring and pinion will fit into a 10.25. You just have to use the 10.5 pininon bearing set and BOTH the ring and pinion. I am 90% sure on this. I bought a 3.73 10.5 gear set to do the same to my truck but haven't done it yet. I know I did a lot of research on this to make sure.
Now for the dana 50 front, I believe the TTB is reverse rotation and the solid is standard rotation. I could be wrong here tho unfortunately. I know it is this way for sure with the older dana 60s and the newwer 60s under the superduties.
edit: This might help I didn't have time to read throught the whole thing but the answer should be in there.
http://www.fourwheeler.com/techartic...ips/index.html
Old May 14, 2010 | 09:46 PM
cowmilker08
That article says that you can use 10.25" parts inside the 10.5" housing.
Which is what I figured, unfortunately I need it to go the other way.
Please keep me posted on how the swap goes. Thanks.
Old May 14, 2010 | 11:37 PM
cowmilker08
What do you guys think about these's sites? I've read 95% of each one so far. The first one has some questionable info. We have full-floating axles, right?
West Coast Differentials: Ring & Pinion Gears, Posi's, Lockers & Axle Parts
Randy's Ring & Pinion. The Differential Experts. Auto Parts & Services.
You all may think I crazy, but I'm seriously considering buying all the tools and learning how to completely rebuild and work on differentials along with a friend. I'm always a sucker for the challenging stuff.
So, how much business would I get from this site alone? LOL
Old May 15, 2010 | 07:28 AM
93f1505.0L's Avatar
93f1505.0L
I have never delt with either of them.
The housing are the same. They have the same diff cover from the first 10.25 until the current 10.50.
It will be a while before I get the swap done. I have to get a set for my dana 60 too and just don't have the funds now.
I have almost 100% that you can do it. I looked and read for a long time before I bought the gears and I wouldn't have bought them if I was almost sure. The only reason I am not 100% is because I haven't done it myself. You just need the 10.50 bearings when using those gears.
Old May 15, 2010 | 10:03 AM
Fullcrew7.3's Avatar
Fullcrew7.3
I didn't know the newer D60 front's were standard rotation. Hmm, learn something every day.
Old May 15, 2010 | 11:04 AM
93f1505.0L's Avatar
93f1505.0L
unfortunately I dint learn until I already had a newer D60 gear set in my garage.
Old May 15, 2010 | 01:39 PM
Fullcrew7.3
I see. I sorta did the same thing and bought a set of 3.55's for a D60, but they were standard and my front is hight pinion (reverse rotation). Shoulda done some more reading first.. D'oh!
Old May 15, 2010 | 01:45 PM
93f1505.0L's Avatar
93f1505.0L
I have 3.55 now and I wouldn't recomend them. I went from 4.10 to 3.55 with my d60 swap and don't like it. There was no MPG change either. I might even go back to 4.10 and just skip the 3.73s.
Old May 16, 2010 | 07:02 PM
59JEEPSTANG's Avatar
59JEEPSTANG
Randy's Ring & Pinion is top notch, dealt with them a couple times. (on Jeeps) The also have decent tech support.
Paul
Old May 16, 2010 | 08:18 PM
Brown Falcon's Avatar
Brown Falcon
I went from 4.10's to 3.55's also and regret the decision. I was much happier with 4.10's
Old May 16, 2010 | 09:56 PM
cowmilker08
I'm pretty set on 3.73's.
I am happy I kept reading on this subject. I really want to do this myself now. I just like these things I guess.
Also I am glad to see some support for the one website.
I still have a lot of reading to do, though!
Old May 16, 2010 | 11:32 PM
  #28
93f1505.0L's Avatar
93f1505.0L
Please report back on the 3.73s. I am interested in doing the swap. Like I said I already have the rear just need a high pinion d60 front. Maybe call up that website and see what they have to say about capatability.
Old May 17, 2010 | 02:35 PM
  #29
cowmilker08
You might have to wait until the end of summer, unfortunately.
I'm am trying to pay this truck off first, then this computer, then getting married and trying to buy a house.
So, it could be awhile.
Old May 17, 2010 | 08:32 PM
  #30
93f1505.0L's Avatar
93f1505.0L
I know how that is never ending bills. Mine should be paid off this year.
M3dragon
N. California Chapter
Sep 11, 2015 09:23 AM
M3dragon
Nevada Chapter
Sep 11, 2015 09:17 AM
Greywolf
Tennessee Chapter
15
Dec 28, 2014 12:57 PM
hhf250
1997 - 2003 F150
Apr 1, 2014 06:41 PM
oldmerc
Sep 23, 2011 09:35 AM
