Sponsored by: Real Truck
Air Bag Problem
Old May 8, 2010 | 05:01 PM
timster24's Avatar
timster24
Air Bag Problem
OK I figured out the dinging was from a burnt out airbag bulb. Fixed that now I am getting a 35 airbag code (pass airbag low resistance/short) and a 71 (pass. airbag disable module fault).
Does anyone know the best way to diagnose the problem, without going to the dealership and paying an arm and a leg for them to drive it into the building? Or what the problem could possibly be?
Old May 8, 2010 | 05:24 PM
gearloose1's Avatar
gearloose1
reset the computers and see if it goes away.
if not check for corrosion in contacts at connectors.
Old May 8, 2010 | 07:01 PM
timster24's Avatar
timster24
I have cleared all codes, I checked the connector behind the glove box, not sure where any other connectors are
Old May 8, 2010 | 07:12 PM
gearloose1's Avatar
gearloose1
Have you done a complete reset as per instructions below?
Old May 8, 2010 | 07:20 PM
timster24's Avatar
timster24
cleared the codes through the solus
