'75 Highboy dilemma
Old May 8, 2010 | 01:01 PM
doc_f250's Avatar
doc_f250
'75 Highboy dilemma
I just bought a '75 Highboy w/ a 410 (swapped in) FE/4-speed, etc.
The front hanger on the rear spring needs to be replaced.
I have a '78 F-350 rolling frame w/ 3" rear springs, hangers, & all.....
I have also read about the 64" GM spring swap......
Are the 2wd truck hangers the same as my Highboy?
The truck will be an off road toy/driver, seldom called to haul anything but ***.
Which would be the best, long-term?
Thanks!
D
Old May 8, 2010 | 04:41 PM
jmm's Avatar
jmm
im in the same delema as you. But the 78 f100 2 wheel is close, and there are other year f100 that might work to. There is going to be some material added to close up some space and some cut but they will work. another option is that some of older chevy's come close ive been told
hope this helps
Old May 8, 2010 | 05:02 PM
doc_f250's Avatar
doc_f250
I just got back from my local yard, tape measure in hand......most were the same on the top spread, wider on the lower rivet spread, & hang lower (below the frame) than on my highboy.
If you come up w/ an idea, let me know.
Thanks for the post!
D
Old May 8, 2010 | 07:49 PM
75F350's Avatar
75F350
If you use a different hanger from a different era truck, dont expect the rivet holes to line up.
Find a hanger set that uses the same width spring as yours, and simply make a reference line relative to the main bolt that attaches the spring. Then measure the same distance on the new spring and transfer a line to it.
Line up the new mark on the hanger against the reference line that was made withthe stock hanger and start drilling.
Use quality fasteners, and verify that your holes are equal from side to side so that the axle is straight, and you are golden.
Its not difficult, though do know that most chebby hangers use a smaller diameter bolt for the spring, so the hanger itself will have to be modified a little
Old May 8, 2010 | 07:52 PM
doc_f250's Avatar
doc_f250
Same era trucks, I checked them all.....'60's, '70's, even the '80's. No highboy's though.
I did scope out a '91 K1500....those are some long springs!!
I basically want the same ride height, but lose the block & gain some ride/flex.
Thanks!!
D
Old May 10, 2010 | 12:03 PM
r2000f150's Avatar
r2000f150
i just got done replacing the front one on my drivers side rear leaf spring i got one at a salvage yardin my area i ground off rivet and replaced the hanger went pretty easy was worried about getting bolt out of spring but it came out ok hope you find one
Old May 10, 2010 | 05:14 PM
armstrongfordtrucks's Avatar
armstrongfordtrucks
I don't know if this will help anyone but ford used the 2 1/2'' leaf spring in the ford cab and chassis DRW up to 1996 and springs fit in the high boys. Maybe a spring shop would have some mounts around. I don't know if they would bolt up the same.
Old May 10, 2010 | 05:29 PM
Hickfied's Avatar
Hickfied
You bought that truck? Did it really have the wrong balance flywheel? Did it wipe out the crank bearings?
Old May 10, 2010 | 05:32 PM
doc_f250's Avatar
doc_f250
Engine looks & sounds good.....motor swap in the works.
66with352
Feb 2, 2014 09:23 AM
PA74F250
Sep 26, 2012 03:57 PM
ghunt
Nov 25, 2009 08:13 AM
CatBob
Jun 29, 2008 01:31 PM
62uni4x4
Offroad & 4x4
May 13, 2004 09:31 AM
