Brake Problems
Old May 8, 2010 | 12:25 PM
mike1589's Avatar
mike1589
Brake Problems
hey guys, so im not all that great with breaks, but I put a new master cylinder in my 78 250 and had the brake lines all disconnected and everything for a while. Just got it all back together yesterday, and i bled them, and now the pedal builds up good pressure when the trucks off, but as soon as its running it just goes right to the floor with barely any pressure at all. Any ideas? I thought I bled them enough but maybe not?
Old May 8, 2010 | 12:54 PM
fmc400's Avatar
fmc400
MSEE
Did you bench-bleed the master cylinder? This is separate from bleeding at the wheels.
Old May 8, 2010 | 01:07 PM
mike1589's Avatar
mike1589
no i didnt..would that really make that much difference and cause the pedal to go to the floor? if so, how do i bench bleed it?
Old May 8, 2010 | 01:12 PM
fmc400's Avatar
fmc400
MSEE
Absolutely - bench bleeding is a must when installing a new master cylinder. Otherwise you'll never get the air out of the master cylinder itself. Did the master cylinder not come with the sheet of paper and two plugs?
Old May 8, 2010 | 01:37 PM
mike1589's Avatar
mike1589
im actually not sure im going to go check right now. I wasnt aware bench bleeding was that important, ill give it a try i thikn that might fix my problem
