1.5" or 2"??
Old May 7, 2010 | 10:55 PM
Rangerrod007's Avatar
Rangerrod007
1.5" or 2"??
I have read all the posts here and you guys have me convinced to go with AS leveling kits, but.....I cant decide if I should go with a 1 1/2" or a 2" kit. I have a 2010 F150 Screw FX4.
I want to put my BFG 305/65/18s on but I think I will need the front lift even tough they cleared on my 08 fine. The 2010 looks lower or has less clearance than my 08.
Any thoughts?
Old May 8, 2010 | 08:03 AM
stephen.osborne1's Avatar
stephen.osborne1
I think either the 1.5 or the 2" will clear those tires. It's more a matter of how you want your truck to sit. A lot og guys complain the AS 2" kit leaves the truck sitting a little "nose up". I have the 2" and I like the way it sits. If perfectly level is what you want, the 1.5 is more up your alley.
Old May 8, 2010 | 09:40 AM
jdrahush's Avatar
jdrahush
I put the 1.5 inch AS leveling kit in my 2004, and I wish I had gone with the 2 inch. However when I installed it I also put 3 inch blocks in the rear.
Old May 8, 2010 | 10:54 AM
Rangerrod007
Thanks for the response. I think ill go with the 2" if it sits too high I can always add some more weight to the front like a supercharger and a push bar.
Old May 10, 2010 | 10:52 AM
rockstate45's Avatar
rockstate45
It does appear to be nose high btu you can't beat the look of a leveled truck!
Looks good Stephen. All you need is some bigger tires! It's interesting to find out the new F150 has such a slight rake. On the Tundras it's taking 2.5+ to get it fully leveled.
-rockstate
Old May 10, 2010 | 08:02 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
2" gets my vote
if the nose is too high, then you can grab the 3" autosprings replacement block and the rear will go up 1" to offset the front
Old May 11, 2010 | 10:04 AM
stephen.osborne1
-rockstate
I'm planning on going about 33" eventually. I need to wear these suckers out first. I can't justify replacing perfectly good tires.
Old May 11, 2010 | 10:41 AM
rockstate45
Man for a 33 you can't beat the look of a BFG AT T/A KO 305/65/18!
Best looking tire in that size IMO.
Best go see what that LSD can do
-rockstate
Old May 11, 2010 | 01:04 PM
stephen.osborne1
-rockstate
I've had the BFG's before and the wet traction sucked. It rains a lot in WA, so that is a big concern. I am leaning toward the Firestone Destination AT's if I can get them that big. I have the MT's on my 2000 and have been highly impressed. BTW- I have an FX4 so no LSD here... Lock it up baby!
Old May 11, 2010 | 09:33 PM
pb34's Avatar
pb34
I have the Destination AT's in 285/70/17 on my '06 and I love them so far. Excellent traction in the snow as well as wet traction although I've only had them for about 7k miles. They seem to be wearing well also.
Mtnhermit
Apr 30, 2016 12:57 AM
slowmans
Ford Truck Parts for Sale
Aug 3, 2012 03:34 PM
texag09
2009 - 2014 F150
Jun 21, 2010 06:01 AM
texag09
2009 - 2014 F150
Jun 8, 2010 12:14 PM
