So i was driving home last night and it seemed like it started missing. But i didn't think anything of it because the carb needs to be rebuilt. But then it would miss so bad i could only run in 1st gear and it would backfire. Then my Tach quit working. Then it died. And it would just click like the solenoid was bad. So i had a friend come and pull me home. So when he was pulling me home i would let the clutch out to get it to start and it would just turn over but not start. So i went out this morning and jumped it and it started right up. Drove it around the yard for about 3 minutes and shut it off. And then it started clicking again. So i tryed jumping the solenoid and it still just clicked. The ALT indicator light has been on since i bought it but i didn' think anything of it since it was charging. When i was sitting there waiting for my buddy to get there i still had enough battery to listen to the radio and have the dome light on. So it's not like the battery was completly dead. So i'm thinking it's not the altenator. But could it be the voltage regulator???
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Circle, from what you are describing, clearly you are not charging. Replace both the alternator and regulator together.
A nearly dead battery will play a radio or light a dome light. They only require an amp or two. But that battery cannot supply the hundred amps needed by the starter.
There are ways to determine whether the alternator is at fault but since regulators are so cheap you would be well advised to replace both.
a battery that wont charge and is toast is one thing, a dead battery is another, but a dead alternator will leave you stranded. when running you should have at least around 14 volts at the terminals, plus indicator on the dash should be normal. the truck is capable of running the ignition system off of a battery alone, until the battery dies and then you are just screwed. and it wont matter how hard you try to use jumper cables, if you have a dead alternator you will be stuck. i think voltage regulators for these are like 10 bucks. i have replaced mine.
so i now charged the battery full and let it idle and drove it around the yard. It started fine, ran fine, and stayed running... I dunno what to think. Is it possible to kill these if the coil gets wet. it was raining that night it died on me.
If you have access to a fluke meter that will help you narrow down your issue. Like D_D was saying if your alt is putting out 14 volts or so it is not the issue.
Vern
Connect your meter to the battery and it should read about 14v at about 2000rpm. If not your charging system is not working. If it were me and your truck is not a restored one get a one wire alternator and throw the regulator away. I did this to mine 20 years ago.
No, I don't think so. that would not affect the starter's behavior.
It sounds very much like a charging problem. A fully charged battery could easily get you by for a short drive, and that is likely what's going on. If you kept going, I'm sure you would have a repeat performance on the side of the road.
Like what everyone is saying, get a voltmeter or fluke meter and check voltage at the battery. You should have around 12V (12.6V? I forget) with the engine off. Then, fire it up, hold it around 1500 or 2000 RPM, and check voltage again. You should have more than the 12.? you started with and less than 14. Or you could just pull the alternator and have it tested.
