I'm stumped
Old May 10, 2010 | 04:34 PM
BCHauler's Avatar
BCHauler
My 351 ran well most of the time but seemed to struggle on hills at highway speeds, ball-less and some hesitation. I tried a whole bunch of things, but solved it by rerouting the sparkplug wires away from each other. Apparently, I was getting a bit of crossfire.
Not sure how that would relate to the poor fuel economy though. Are you running stock size tires. Bigger tires and a speedo that hasn't been corrected for it could cause poor fuel economy calculations.
Old May 10, 2010 | 04:43 PM
rla2005's Avatar
rla2005
Originally Posted by 93F250HD
I believe I got Code 33
then Codes
72 & 73
I wont be able to test fuel pressure for a few days. The truck never stalls and rarely ever even fluctuates at idle, It just has NO ***** going up hills or towing even 2500 pounds.
Your truck should display 3 digit codes. The 33 is the all clear 111 - 111.
Old May 10, 2010 | 04:53 PM
93F250HD's Avatar
93F250HD
OK, so I think I have a better reading on it now
I think its 11 during the first part which would make sense since the light is not on right now
Then its 72 & 73
During the running test its
72
63 (maybe 53)
then it flashes 2 at the end which makes no sense
Old May 10, 2010 | 04:55 PM
rla2005's Avatar
rla2005
FWIW my '92 F350 4x4 w/5.8L and E4OD is a gutless wonder. I get around 12 MPG highway if I run unloaded at 65 MPH. Around town mileage varies from 6-8. I have done a complete tuneup with new filters, MSD cap/rotor/coil, new Autolite plugs gapped @.055", Bassani 3" y-pipe, Magnaflow 3" muffler and a 3" tailpipe. When I did the exhaust I also replaced the O2.
I have replaced yards of vacuum tubing and a few vacuum reservoirs. Add in a new EGR, EVR and PCV valve. I have no error codes or other drivability problems. The stock 3.55 gears and 32" tires are it's worst enemy. The overall diameter is close to the stock size, only a few inches wider.
This thing has only so much power to give. All the parts I put on it have helped very well as a package. Nothing else will make a difference until I change gears, build a better motor and/or go forced induction. Best advice is to take care of any code issue you may have. Then settle for what you have or spend some more $$.
Old May 10, 2010 | 04:59 PM
ymeski56's Avatar
ymeski56
Der Postmeister
How about a base timing bump to something like 14 BTDC?
Old May 10, 2010 | 05:24 PM
93F250HD's Avatar
93F250HD
rla2005 I appreciate the notes, I guess Im stubborn but I refuse to believe that back in 1993 a guy would buy this 5.8L truck for 20/30k new and not even be able to tow q small fishing boat above 40mph on an incline. I believe I am getting closer to figuring it out because it is running stronger on flats unloaded. I am going to try what ymeski56 said with the timing, but I cant get to a timing light until Wed or thursday then i will post feedback. I went and got a new accelle cap and rotor assembly and all new plugs(again). Also someone asked and I run 87 octane.
Old May 10, 2010 | 05:45 PM
rla2005's Avatar
rla2005
I knew there was something I missed....I bumped the timing to ~12. I plan to try some more when it gets warmer.
Old May 10, 2010 | 05:54 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Don't forget you have to have the spout plug removed when checking & adjusting base timing! Just as important, replace it afterwards, or no ECU advance will be added.
Old May 10, 2010 | 05:55 PM
93F250HD's Avatar
93F250HD
Codes updated
OK, so
I have the
11 All clear
then key on engine off
72 and 73
Key on running
172
632
632 seems to do with cycling the tranny after the 4 flashes but before I need to throttle after the single flash, but everytime I do this it never asks me to go to WOT or starts the diagnostic flashes.
Old May 10, 2010 | 06:09 PM
ymeski56's Avatar
ymeski56
Der Postmeister
14's better. 16 BTDC is the sweet spot, if your engine will tolerate it w/o ping. I highly recommend Mororcraft stock copper cores for timing bumps. Double Platinums will not allow as much advance & stocks are safer, designed to fail prior to possible piston damage, if your hard of hearing when it comes to PING! Cleaning the Combustion chambers w/ Seafoam (through the power brake Vac hose while at warm idle, shut down for 15 min, then rev out the crap) is almost a priority first, as deposits are usually the reason engines disagree w/ the Mod.
Old May 10, 2010 | 06:25 PM
rla2005's Avatar
rla2005
I have standard Autolite copper core plugs. I've had good luck with them in many of my Fords. Timing was set with SPOUT pulled, then returned to it's normal service position. I started out with 12 BTDC when the weather was cooler. I am waiting for some normal 80+ summer weather trying to sneak up a few more degrees.
Old May 10, 2010 | 07:53 PM
ymeski56's Avatar
ymeski56
Der Postmeister
I know you know about SPOUT plugs, that comment was for 92F250HD, in case it was his first time. Autolite C/C's will work fine too!
Old May 10, 2010 | 09:07 PM
  #28
93F250HD's Avatar
93F250HD
By spout plug do you mean the little gray cap in the harness over by the OBD1 test ports?
Old May 10, 2010 | 10:50 PM
  #29
ymeski56's Avatar
ymeski56
Der Postmeister
If that's where your TFI module is also.
Old May 10, 2010 | 11:50 PM
  #30
rla2005's Avatar
rla2005
My bad.....
