Sponsored by: Real Truck
01 7.3 starting problem
Old May 7, 2010 | 11:25 AM
wyattwie's Avatar
wyattwie
My o1 wont cyle the glow plugs, if I jump the gpr it fires up. I have changed the relay no change. There is power to the timer and the relay but with the key on the relay wont power up the glowplug side and there is power to the small terminals with the key on. Checked all the fuses and fuseable links around the timer and the relay. What is next?
Old May 7, 2010 | 07:25 PM
jonrjen's Avatar
jonrjen
Try going over to this link
1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Same great site as you are on, only more direct related to the 7.3 PSD, sure you can find your answer over there.
Good Luck,
Jon
