Sponsored by: Auxito
turn signal bulb
Old May 6, 2010 | 10:36 PM
97XLT4X4's Avatar
97XLT4X4
turn signal bulb
replace from underneath?
or do i remove the headlights and the torx screw on the top and get it that way?
Old May 7, 2010 | 05:38 PM
steve(ill)'s Avatar
steve(ill)
look on top of the back of the head lights. mine has a steel L strap that pushes down nd grabs the plastic square nuts in the sheet metal. pull the L strap up (twoper light) and pop out the light. then you can get to the turn signal lens screws. No adjustments needed on the hedlughts if use use the L brackets to reposition.
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
