Festus, to be on the safe side, I'd disconnect the ground to test it. If it is truly grounded, you'd be OK. If it was not actually grounded, you might nuke the controller.
If you think you have a grounding issue for the controler. Run a separate ground wire direct from the battery to the controler grounding bolt attach it there (avoiding the grounding from the block). I did this 6 years ago and my grounding problems / controler problems went away.
