Doing project this weekend, need advice
Is there somewhere I can get a vacuum diagram for my truck to make sure its all right or should haynes manual have a good enough one?
Now sinse I cant take the smog pump out should I leave the vacuum to it wide open with maybe a filter of some sort on it, and run the exhaust into my exhaust? Also with the exhaust do yall think it would sound good if I with the EFI manifolds ran true duals with 2" pipe instead of the 2 1/2" pipe with glass packs on the end an run both straight out the back on the same side, or should I leave it like it is with the y into single 2 1/2" and put headers on it with a glass pack at the back end?
Is there anything else I can do now with the intake to increase power before I put it back to gether without messing with my computer? I cleaned the cylinder heads with a rag and carb cleaner but I want to clean them better I think any suggestions?
Also I snagged some 302 injectors from a local junk yard and I was wanting to make sure they would be good for my truck with the EFI? They are the same injectors the only difference is the ones on my truck(300) have a single little jet it seems, and the 302 ones have like 3 or 4 little spray holes, could I put those in without my computer going nuts?
I am wanting to find an H7 code rear axel(limited slip 3.31 gears in it) I think with that motor having the low-end power it does and with what I've done if it runs better I think those gears would be good for mileage around town. Still being low enough with the motor to where I could stomp it in first an get it to boil them instead of hopping. Do you believe that those gears would be good for me? Im not looking to tow alot, I might pull a trailer with a car or a load of scrap metal here an there thats it. I really want to be able to show off an ride out.
Sorry to ask so many questions I have never really dealt with performance on a vehicle just keepin it running so Im not sure what I can an can not do being my 300 is EFI, and I would like to keep the gas mileage reasonable. Thanks for any and all the help and advice you all give.
o one last thing with the cumbustion chamber should I atleast smooth the edges and maybe with some sort of tool try to clean them up an smooth the inside of it too? Just so long as I dont open it up any I should be good right? I hope so. again thank you...
Porting the intake and exhaust runners a bit will do no harm as long as one does not go hog wild.
A three angle is a good idea why the head is off. I generaly also plane the head flat also why it is off. That is my standard procedure anytime the head is off. DONT "MILL" THE HEAD! only plane it flat.
On a seperate note before I put everything together, should I port the manifolds too or should I leave them alone? Also what should I use to clean the cylinders inside my motor? I tried to use a drimal with a brass bristle brush on the end of it but I'm afraid that wasn't a good idea, it cleaned it up a little but didn't pull all the varnish off the top. What should I use to clean those off?
Once again dont grind the inside of the combustion chamber. Leave it alone. Do I got to take your dremmel away?
Milling is the delibriate taking of material off of a cylinder head or block to lower the deck hight and raise the CR. Change the CR on a EFI engine and you are going tro have a bad day.
Planing is just a scratch cut that brings the head flat again for propper gasket sealup.
ooooo ok the guy told me that milling was the same thing as flat planing. Is that something I could do myself? Does'nt really sound like it.
Yeah you might need to take it away I'm sure Im going to use it for something else in this prosses.
I guess I should go ahead an pull the pistons I have had a low-end knock for awhile now just have'nt felt like pulling the pan an all but since I've gone this far I might as well go all the way.
Planing as I said is just a scratch cut to bring it square. Milling is a heavy cut designed to reduce the CC of the chamber or remove major imperfections. Milling is called milling because you use a mill to remove the material. Planing is called planing because you use a plane (horizontal grinding machine) planes the head parellel.
If you are going to pull the pistions I would check the bore and then debate either a re-ring or a rebuild.
also should I pull the crank an let the automotive class next door sneak it in an have the teacher help them mic it?
Really now Im to the point where I need to get it back together like yesterday an the guy hasnt started the head yet. He says he's been doing this for years an this an that an he's never had a problem with resurfacing a head and it messing up the efi.
you guys work on these things all day everyday he just does machine work.... So let me know for sure if he machines it an it ****s my computer up im ****ed, if I dont get it resurfaced which I really dont see it needing to be. but get back to me quick cuz its gettin close to the end of the week. he will be starting on it soon. So I need to know whether to tell him not to surface it that Ill do that myself or not.
I am an industrial mechanic at a sugar factory. Ive had the head off a 300 about twice. I have had the heads off of probobly 50 engines in my lifetime, so I think I can tell you how this is done.
DO NOT GRIND ON YOUR OWN HEAD! Man you got some crazy ideas.
You will still need to fix the EGR probloms. Good luck, I hope it runs good for you.
1) I would say my spelling is the leased of your worries dude
