64 Radiator
Old May 6, 2010 | 12:32 PM
joe cowan's Avatar
joe cowan
64 Radiator
Hi Guys: The search turned nothing. I know I saw something on here. What years of radiators will adapt to a 1964 F100 w/292Y engine? Thanks for any help. Joe
Old May 6, 2010 | 04:06 PM
gottahaveaford's Avatar
gottahaveaford
I have a 223 in mine, but I looked at the numbers off my radiator (clearly not original becuase of the chysler logo) and its out of a 1971-72 Chysler w/318. Obviously not the easiest thing to find either but it looks like it bolted right up fine. Probly not any help just thought I'd let ya know.
Old May 6, 2010 | 04:16 PM
airharley's Avatar
airharley
Funny you should post this. Ready-Rad sells a few that may bolt in according to a source that sells junk panels and cheap china made OEM parts. I haven't any experience with these particular ones but if the diamentions are correct then why not. You can also go to the Ready-Rad site and see the specs in more detail.
Go to your local part house and order one of the following:
43-2971 (18"H x 23 3/4"W x 1 1/4"D) 3 rows w/ trans cooler
43-2967 (17 7/8"H x 23 3/8"W x 1 1/2"D) 3 rows w/ trans cooler
Old May 7, 2010 | 04:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C1TZ8005T .. Radiator / Obsolete
Fits: 1961/64 292 F100/250 & F350 w/SRW.
The following will also fit, but it has a thicker core:
C3TZ8005E .. Radiator / 26 3/4" width / 18" height / 2 1/4" core thickness / Obsolete
Fits: 1961/64 292 F350 w/DRW & F500/700 / 1961/64 292 B500/700 (School Bus) / 1961/64 292 N500/600.
Note: All of the above use the same radiator support: C2TZ16136G.
No Ford Dealer or obsolete parts vendor has any.
Old May 7, 2010 | 07:33 AM
fordman67's Avatar
fordman67
I have had great luck with Rock Auto.com The prices are dirt cheap compared to all the parts houses here.
joe blow
Jan 17, 2013 05:06 PM
joe blow
Oct 26, 2011 06:13 PM
granadojl
Jan 7, 2008 07:17 PM
bronco joe joe
New Member Introductions
Sep 13, 2006 04:48 AM
Joe
Dec 5, 1999 08:45 PM
