Sponsored by: Real Truck
Four Wheel Drive Question
Old May 6, 2010 | 08:30 AM
jimbeam87's Avatar
jimbeam87
I have an 02 F250 that had the 4X4 lockouts with the auto setting or locked in full time setting. I replaced those with Warn hubs and they seem to be working fine except for one thing. I have it in the free position and when I turn the main shaft going to the front end the shaft to the driver side turns to. Is that shaft suppose to turn even tho its not locked in?
Old May 6, 2010 | 09:31 AM
mmaliga's Avatar
mmaliga
Either shaft might turn (both if Posi).
True test would be to turn the wheel to see if the shaft turns.
Sounds to me like if the shaft turns and the wheel doesn't, it is unlocked.
Old May 6, 2010 | 10:28 AM
rotun's Avatar
rotun
Reads ***** rules!
It's o.k. that it turns, just "static" in it. If both wheels are on the ground and you can turn the driveshaft by hand then it's fine. If it were a "hard lock" and not just static pressure you would not be able to turn the shaft by hand.
Auctioneer NJ
17
Oct 17, 2014 08:46 AM
Bonanza35
Jan 28, 2014 03:32 PM
drburnerllc
Sep 10, 2012 03:31 AM
tipaktp
2004 - 2008 F150
May 31, 2011 10:28 AM
MikeD916
1983 - 2012 Ranger & B-Series
Jul 7, 2004 01:30 AM
