Putting in a switch..
Old May 5, 2010 | 05:16 PM
Wicked Endings's Avatar
Wicked Endings
Hey guys,
So, as some of you know...
My back-up lights don't work. I was going to get a new neutral safety switch (back up switch) but, everything but the light part about it seems to be in order. So, i'm just going to keep it the way it is.
For my lights however, I took the wire heading to the lights and extended it, putting it through the firewall and now it's sitting on my truck seat.
I'm going to get a switch, so when I turn it on, the lights come on (for when i'm going to go backwards)
However, I need a power source. Where is the best place to hook up a wire so I can hook that power wire to the switch?
Thanks!
Old May 5, 2010 | 06:29 PM
fepowerguy8's Avatar
fepowerguy8
I usually just stick the power wire in the fuse block. Use the ignition fuse for keyed power and lighter for constant power. Or wire it into one of those things too.
Old May 5, 2010 | 06:31 PM
JimsRebel's Avatar
JimsRebel
I would just use the power feed wire that was feeding the backup light switch on the auto tranny. That way you are just replacing one switch with another switch.
My truck has a C6, do you really have a C4 in a 1985 F150 4.9?
Old May 5, 2010 | 06:43 PM
Wicked Endings
Use the ignition fuse for keyed power and lighter for constant power?
How am I supposed to wire into that?
And what do you mean wire it into one of those things too?
Old May 5, 2010 | 06:49 PM
fepowerguy8
I strip the end of the wire and stick it in the fuse block where the fuse goes then stick the fuse in and it should hold it in place. I hate splicing wires so when I wire tachs in I just do this. What I mean by wire it in is you can trace where the power wires go for either the ignition switch or the lighter, there should be studs sticking out and just put en eye end on the wire and bolt it on the stud. Either way it should not move.
Old May 5, 2010 | 06:50 PM
Wicked Endings
I actually might do that "stick it in the fuse" thing.
And if that doesn't work, i'll wire it into the ignition or wire wires.
I'll try that tomorrow!
hwyhogg
15
Dec 8, 2014 08:15 PM
Bubba-88
Electrical Systems/Wiring
Mar 27, 2014 07:18 PM
gpence
1978 - 1996 Big Bronco
Mar 21, 2013 06:54 PM
EricAlex66
Jul 10, 2011 02:59 PM
Ddog1023
1983 - 2012 Ranger & B-Series
Mar 26, 2004 01:31 PM
