1990 F150 5.0 engine problems
Old May 5, 2010 | 03:22 PM
jknight03's Avatar
jknight03
Hey guys. I'm new to the forums as well as owning a Ford truck. I've got a 1990 F150 XLT Lariat 5.0L Manual 2wd that's giving me some problems. For one, it idles high. I'm sure that's probably a vacuum leak somewhere But, what's got me stumped is this: when under a load at low rpms all it seems to do is stutter like it's running on 4 or 5 cylinders. Extremely under powered. Once you get above about 2500 rpms it smooths out some, but still feels under powered. It has new motorcraft plugs and new wires (I think they're "exact fit"). I've routed the wires so none of them are touching. The truck has dual tanks and it runs the same off either tank. Any ideas? Thanks!
Old May 5, 2010 | 03:26 PM
Hitokori's Avatar
Hitokori
cap, rotor, fuel filter?
have u replaced those as well
Old May 5, 2010 | 09:31 PM
ken2400's Avatar
ken2400
On a 1991 I am working on I had two cans I just replace with one larger plastic can from a 1994.
Check the two cans on yours and see if the are rusted.
One is on the pass side and the other under the coolant overflow tank.
Good luck.
Old May 6, 2010 | 02:01 PM
jknight03's Avatar
jknight03
I replaced those today and it is running MUCH better. Still not 100% but I'm happy with the results. Thanks! I think a different set of gears would help out the rest. I'm sure it has the stock gears and the truck has pretty tall BFG All Terrains all the way around (285/70/17). The tires have changed the gear ratio enough to make my speedometer 10 mph off at 55 (says I'm going 55 when actual speed is 65).
Old May 6, 2010 | 02:05 PM
jknight03's Avatar
jknight03
Good luck.
I checked the cans--they both seem to be fine. The one under the coolant overflow tank was holding vacuum when I unplugged the hoses. The other one I took off and inspected and it seems sealed tight. The truck still wants to idle around 1200 to 1500 rpms. I checked all the hoses I could see. I sprayed throttle body cleaner around all visible hoses and connections to check for leaks that way and couldn't find anything.
I forgot to mention I cleaned the throttle body and idle air control valve too. Air filter seems fine and I've also replaced the PCV valve.
Old May 6, 2010 | 02:38 PM
Lazy K's Avatar
Lazy K
Ford Fuel Injection Throttle Position Sensor (TPS) Use this link to test the TPS. Also if you look in the list on the right of that page you will see a link "Self Test" for instructions on getting any stored trouble codes. Might be worth doing.
Old May 6, 2010 | 03:37 PM
Conanski's Avatar
Conanski
Yes pull the codes you still have a problem somewhere.
Old May 6, 2010 | 04:16 PM
jknight03's Avatar
jknight03
Great! I was wondering how I was going to get codes off of this truck. I have an OBDII scanner but nothing for OBD. I'll check to see what codes are stored and follow up. Thanks a lot for the help!
Old May 6, 2010 | 07:04 PM
ken2400's Avatar
ken2400
The one on the pass side can be check by hooking up just the vac source hose and putting your finger on the other input to the can. Pull your finger off in 30 sec and see if vac holds.
Good to read the truck is getting better.
Old May 6, 2010 | 08:46 PM
jknight03's Avatar
jknight03
I'll try this tomorrow along with reading the codes. You guys are great! I'll keep posting until I get this thing straightened out. I bought the truck real cheap needing a clutch so I couldn't test drive it. It ran real good sitting in the driveway! ;-) Haha...
Old May 7, 2010 | 11:21 AM
ken2400's Avatar
ken2400
Should have added if the can is not too rusted and not holding vac look for the holes and use the metal/silver duct tape to seal them up.
Old May 7, 2010 | 11:26 AM
Ricky B's Avatar
Ricky B
Whatever you do, DO NOT touch the 'idle adjustment' screw at the throttle body. I know it's tempting to do so....but don't.
Btw I bought my Equus OBDI reader at Kragen for $22.00. Much more fun than counting 100's of flashes on the dash......
Old May 13, 2010 | 02:05 PM
jknight03's Avatar
jknight03
Alright, I just now got around to checking the codes... been busy with a cousin's wedding. The code that pulled up was 23 "Closed throttle TPS voltage higher or lower than expected." So, I think we've found the idle problem. I'll replace the tps and check back. Thanks!
Old May 13, 2010 | 02:22 PM
Ricky B's Avatar
Ricky B
No! Before you throw money on a new one, remove yours, and run the Haynes test on it. If it passes, disassemble it, clean it and re-install it---very carefully----
Trust me on this one..........
Old May 13, 2010 | 09:31 PM
jknight03's Avatar
jknight03
I put a meter to it to test the voltage and it was over 2 volts at closed throttle and just under 5 at wide open throttle. I read that it's supposed to be under 1 volt at closed throttle. I disassembled, reassembled and still came up with the same results. So, I think this one is done unless you have any suggestions. I have one waiting on me to pick up in the morning.
