Turbo not working....
Old May 5, 2010 | 12:43 PM
cclc1021's Avatar
cclc1021
Hey guys,
I have a 1996 f250 PS 4x4 ext cab that I brought about a year ago. Today I noticed that I couldn't here the turbo. Outside of not hearting it is there another way to check to see if it's working? If it's not working can it be repaired or do I need to replace it? From what I'm hearing it can be pricey. Any feedback would be greatly appreciated.
Old May 5, 2010 | 12:59 PM
JamesHajek's Avatar
JamesHajek
Was it running rough? Any other symptoms besides not hearing it? How many miles? You can rebuild turbos for not too expensive. But lets figure out if you just weren't hearing it, or it really is crapping out first. No sense in fixing what aint broke. Do you have a boost gauge?
Old May 5, 2010 | 01:04 PM
chicagodragon's Avatar
chicagodragon
its slso tough to hear with stock exhaust
Old May 5, 2010 | 01:07 PM
jleal_21's Avatar
jleal_21
hey is a d66 a bolt on or does it need to be modified?
Old May 5, 2010 | 01:09 PM
JamesHajek's Avatar
JamesHajek
Direct replacement to our stocker.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old May 5, 2010 | 01:16 PM
superduty4x4's Avatar
superduty4x4
Remove intake tubing, start truck. If the turbo is spinning its working. The real question is, how well? If the turbo is damaged or if you have a leak some place is when you start having problems. Make yourself a boost leak detector and see if everything is sealed up good. Replace your air filter if its been a while and you should be set.
Old May 5, 2010 | 01:17 PM
cclc1021's Avatar
cclc1021
The truck rides great and just not hearing it was the only symptom. I have 154k with no turbo guage.
Old May 5, 2010 | 01:23 PM
JamesHajek's Avatar
JamesHajek
I would take off the intake tube and check the play in the shaft. Its gonna move a hair but you dont want excessive play. Also check for dusted fins. If both of those look good. I would say your turbo is fine.
Old May 5, 2010 | 01:27 PM
cclc1021's Avatar
cclc1021
Hey Superduty I will definitely try that but what is a boost detector?
Old May 5, 2010 | 01:30 PM
chicagodragon
look in the post under this one
Old May 5, 2010 | 01:31 PM
chicagodragon
i meant the next thread
Old May 5, 2010 | 01:43 PM
superduty4x4
Basically a PVC pipe cap with a tire valve stem in it that you clamp to your intake tubing and pressurize to 20psi or so to make sure all the boots and clamps between the turbo and the motor aren't leaking.
When inspecting the turbo for play (1) make sure things are cool enough to touch and (2) a little side to side play is normal, ANY in and out play is bad. The edges of the wheel should be straight and sharp- no jagged or rounded edges.
Old May 5, 2010 | 04:51 PM
bearhugger's Avatar
bearhugger
If truck is running good,how could the turbo be bad,just asking.
Jim
Old May 5, 2010 | 07:30 PM
Brown Falcon's Avatar
Brown Falcon
Could you hear the turbo before and you can't hear it now? Or can you just not hear it?
If you have the stock intake and/or stock exhaust you probably won't hear it.
You just bought the 6637 intake and a downpipe right CCLC? After those mods, the 6637 especially you should be able to hear the turbo. Gutting the cat (or removing it) as well as a more open muffler will help too.
If it's running well it's probably not bad. If it is accelerating really slow it could be going bad.
diver110
EcoBoost (all engine sizes)
Aug 17, 2011 10:05 AM
RDC F250 7.3
Oct 15, 2007 01:30 PM
ponch37300
16
Jul 29, 2007 10:39 AM
tjbeggs
Nov 11, 2005 09:03 PM
tnardo
Jul 28, 2003 10:12 AM
