Should gas cap hiss when opened?
Old May 5, 2010 | 10:45 AM
sslick's Avatar
sslick
'94 F-150 302 dual tanks...both caps have something about "hissing" written on top of them. Like, "carefully open till hissing subsides". Something to that effect anyway. Nonetheless, neither tank hisses on my truck. The reason I'm looking into this is that I'm still having hard starting problems with the 'ol girl. Starts up quickly the 1st time on a given day, the rest of the day it'll crank for about 5 secs or so before it'll fire up. I can usually smell gas as well when it does this and although intermittent, it has this problem more often than never. I've been dealing with this for quite some time now and I've done everything that I know to do: new plugs/cap/rotor, timing set (w/SPOUT unplugged), new FP regulator. Also checked codes and got nuthin', checked fuel pressure w/ engine running and not running and is per spec. This is essentially driving me nuts...the truck runs great otherwise and gets me 16MPG around town. Anyone had this problem and/or have any suggestions on how to remedy? I really can't afford to take it to the dealership!
Old May 5, 2010 | 11:43 AM
quicklook2's Avatar
quicklook2
hissing normal.
Old May 5, 2010 | 03:55 PM
Eddiec1564's Avatar
Eddiec1564
The hissing noise is the gas expanding when it warms up. With engine off, the vapors are held in the tanks and charcoal canister(under hood pass side front frame). When engine is running it will purge the vapors out. I get this alot down here in Florida, where the temps can swing 30 deg from night and day.
Does the fuel pressure stay up with engine off? You may have pressure bleeding down. Also was the fuel filter replaced too?
Old May 5, 2010 | 05:04 PM
Duramaxfanatic1's Avatar
Duramaxfanatic1
yes it is normal for it to hiss
Old May 6, 2010 | 11:07 AM
sslick's Avatar
sslick
Yes, fuel pressure stays up with engine off. Fuel filter replaced also (what a friggen pain that was. I've never had so much trouble with a fuel filter before!) Isn't there a pressure valve in each tank as well? As I said, I really dunno what's going on at this point. I'm just grabbing at straws, hoping to grab the right one.
Old May 6, 2010 | 11:14 AM
85e150's Avatar
85e150
If you are smelling gas, check your evap system as described in previous post. Canisters and lines can deteriorate, and fumes might could mean you have a leak. Worst case: BOOM.
Old May 6, 2010 | 11:30 AM
sslick's Avatar
sslick
Isn't there a pressure relief valve in each tank as well? I recently patched a small leak in the rear tank, so that may explain why the gas cap wouldn't hiss on that tank. I'm just grabbing at straws here trying to solve my hard-start problem, hoping to grab the right straw! This may not even be a fuel related problem, but something else causing the delayed starts, causing the flooding...thus, the gas smell. BTW, I've also verified the operation of the coolant temp. switch and the intake air temp switch as well.
Hankster1958
Dec 8, 2016 08:01 AM
thechainsawman
Nov 15, 2016 10:46 AM
1986stepsidef150
Jul 22, 2012 09:45 PM
BOB D
35
Feb 3, 2011 07:11 AM
matts156
Dec 30, 2009 11:53 PM
