2 barrel carb problem
Old May 6, 2010 | 02:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by KC63
where does the check valve go on this one? carb tag says C 3TF H
There isn't one.
From the 1957/63 Ford Truck Parts Catalog:
C3TF-H = C3TZ9510U .. 2V Auto-Lite Carburetor / Section 95.14 / Parts list #14A
C3TZ9A586A .. Carburetor Kit (later replaced by D4AZ9A586A [Motorcraft CT499D].
C4AZ9576A .. Accelerator Check Valve / Use with carb tag codes: C4TF-AE; AH; AJ; BM; BR; BS & C6PF-N.
In other words, the check valve was not used with the C3TF-H carburetor.
btw: The post you quoted in Post #15 was originally researched and typed by myself...for FTE member 64 F-100 in response to his inquiry about his carb.
There's only a couple of members in this forum that have the Ford truck parts catalogs. Usually, only myself and Don (camperspecial65) post part numbers from them.
Old May 6, 2010 | 08:46 AM
PawPaw's '66's Avatar
PawPaw's '66
What brand of kit did you get
I don't remember what brand was on it but it came from a local parts store.
did you blow the passages out with compressed air
I did not use air but I did use a can of carb cleaner with the straw and blew through all of the holes and they all seemed clear. I guess I should have used air also.
Old May 6, 2010 | 09:34 PM
Big Daddy T's Avatar
Big Daddy T
FOUGHT THAT PROBLEM A LONG TIME! 4 BARRELL HOLLEY AND 390 INTAKE AND ALL IS WELL! MORE POWER TO BOOT!
JohntheInventor
1961 - 1963 F100 Unibody
Jun 20, 2017 01:38 PM
Tarheel Blue
May 4, 2017 05:09 AM
captanron
Jun 17, 2016 11:46 PM
MTf100
50
Oct 22, 2015 09:31 AM
markeyd
25
Aug 30, 2015 08:52 PM
