wierd temperature jump
Old Jan 31, 2003 | 10:36 AM
oft's Avatar
oft
Hello all,
Couldn't post for a while but Mil1ion fixed me up, Thanks Mil1ion.
Reason I wanted to post was that I noticed something wierd with my temp gauge the other day. I have an aftermaket electric guage installed, about a week ago I noticed the temp had climbed to 210 which it has done b4. Then, in about 3 seconds it dropped to 180 and stayed there (usually where it is) Is this normal? Is my thermostat OK?
Jayson
78 Ford F100
Old Jan 31, 2003 | 11:47 AM
kaotikedge_111100's Avatar
kaotikedge_111100
Sounds to me like your thermostat might be getting stuck shut and then opening finally....maybe you should replace it, they are very very cheap, gasket and thermostat under $20. If that isn't the problem it would have to be your gauge acting goofy, there is nothing else that I can think of that would cause such a sudden change in temp unless some of your hoses or radiator passages were getting blocked temporarily and then getting unclogged. Good luck!!
Old Jan 31, 2003 | 11:51 AM
beartracks's Avatar
beartracks
You might also check the wire from the sensor to the gauge and make sure you have a good connection on both ends and no shorts to ground.
Old Jan 31, 2003 | 12:49 PM
oft's Avatar
oft
OK. REplaced that stat when I put the engine in, it's a year old. Is 210 an OK temp. At what point should I be worried?
Jayson
78 F100
Old Jan 31, 2003 | 12:50 PM
dfisher1's Avatar
dfisher1
Oft,
Have you seen this happen more than once?
Does it happen identically every time?
Was the truck moving or sitting still?
Highway or city?
There a few things that could cause this.
Do you have a factory gage?
What was it doing?
Give us some more detail.
KingFisher
Old Jan 31, 2003 | 01:08 PM
oft's Avatar
oft
I was driving but slowly. I have never noticed a fluctuation that fast. Temp generally stays at 180 - 190 but will climb to about 210 - 220 the odd time mith no apperant rym or reason, sitting still, going fast, slow whatever. It usually drops back down to 180-90. It's an aftermarket electrical gauge.
Jayson
78 F100
Old Jan 31, 2003 | 02:26 PM
macguyver's Avatar
macguyver
Sounds like the thermostat is hanging a little. Once it opens it takes a little while for the cooler water in the radiator to reach the sender which should be close to the thermostat. If your radiator cap is good 210-220 should be no problem at all. Under pressure 235-240 would be considered getting close to hot. No worries. If you do replace the 'stat go with the Robert-Shaw. It has a bleed orifice to burp the trapped air, or drill a 1/16 hole. That will also help to keep at least a little coolant circulating in the radiator. Hope this helps.
Greg
Mil1ion
Washington Chapter
18
Feb 17, 2008 02:37 AM
Mil1ion
Alberta Chapter
May 25, 2007 01:46 PM
Mil1ion
1978 - 1996 Big Bronco
Jan 6, 2003 09:36 PM
Mil1ion
Nov 24, 2002 02:04 PM
Mil1ion
Dec 9, 2001 01:43 PM
