302 Engine Rebuild HELP!!
Old May 4, 2010 | 08:13 PM
JoeTaco1's Avatar
JoeTaco1
Question 302 Engine Rebuild HELP!!
Hello,
I have an '86 F150, with a V8 5.0L, EFI 302 Small Block.
My dad and I just got done with a complete rebuild, and we just put the engine into the truck.
We tried priming the oil pump, as it said in the manual. By turning the engine over without the spark plugs a couple times.. and we tried.. and we tried.. and we tried.
Now we've checked the oil level and are about at the max fill line.. yet we're not getting oil pressure.
Can somebody help us?? We need it!!
Help is appreciated..
-jt
Old May 4, 2010 | 08:26 PM
bashby's Avatar
bashby
Pull the dist and run the oil pump with a drill until it primes or just keep on cranking it and hope it primes
first today's Avatar
first today
Try posting in this section also for more help.
Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) - Ford Truck Enthusiasts Forums
Old May 4, 2010 | 10:39 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Don't keep cranking it, thats how cams get wiped... Pump it up with a drill!
If you still don't get oil pressure, time to pull it apart and find out why!
-Enjoy
fh : )_~
Old May 5, 2010 | 08:27 PM
djcapron's Avatar
djcapron
Drill only! Should of been done before you put it back in!
06FUN
Oct 29, 2016 07:53 AM
Lance Hogan
23
Nov 20, 2011 07:42 PM
BubbaT
17
Sep 6, 2011 12:03 PM
JoeTaco1
May 6, 2010 01:53 PM
rammen99
1997 - 2003 F150
Jun 7, 2004 08:59 PM
