Question ?
Old May 4, 2010 | 07:56 PM
r-kid's Avatar
r-kid
Question ?
When my fuel gets below 1/4 tank the engine develops romp romp and runs a little rough. What causes this ? bad fuel at the bottom of the tank?
Thanks Ron 2000 7.3
Old May 4, 2010 | 07:59 PM
bigal614's Avatar
bigal614
Air in the fuel maybe?
I'll be doing the Hutch/Harpoon mods as soon as my fuel gets low.
Old May 4, 2010 | 08:21 PM
cajun81's Avatar
cajun81
the fuel line cracks in the tank. you can drop the tank and fik it or do like i do and refill the tank befor it gets to 1/4 tank
Old May 4, 2010 | 09:26 PM
Pocket's Avatar
Pocket
Thanks Ron 2000 7.3
It's a fairly common issue that the in-tank mods can fix. The stock pickup assembly can draw in air when fuel gets below 1/4 tank, causing a rough running engine and additional injector noise.
For right now, don't let it fall below 1/4 tank. Air in the fuel can be harder on the injectors over time. When you get a chance, drop the tank and perform the modifications to fix it. Several places sell kits, including ITP Diesel and Diesel Innovations.
At the same time, it would be a good idea to do the pre-pump mods too to get rid of the quick connect fittings. Those also tend to fail over time, and draw air into the fuel lines. Quick connect fittings work fine when they are under pressure, but since they are located before the fuel pump, they are under vacuum and don't work well that way. Both of those places I mentioned also sell pre-pump kits.
Old May 5, 2010 | 06:41 AM
r-kid's Avatar
r-kid
Thanks for the help. Ron
Old May 5, 2010 | 07:08 AM
HD Rider's Avatar
HD Rider
Thanks Ron 2000 7.3
Here is the fix for you.
https://www.ford-trucks.com/forums/9...ml#post8743168
