E350 remote door lock module
Old May 4, 2010 | 07:32 PM
andrewzx92000's Avatar
andrewzx92000
Hi folks. I bought a used 2005 E350 v10 15 passenger van and it came with no remote door lock button thingy.
So I went to the dealer and they ordered a remote and programmed it but nothing happened, so they told me it was not set up for remote door lock operation.
It has electric door locks in it now XLT I can operate the locks with one button up front or back.
Does anyone know what it would take to make it work. Is there a module I can plug into my fuse box somewhere and get the remote option working?
Any help appreciated.
Andrew.
Old May 5, 2010 | 03:20 PM
gearloose1's Avatar
gearloose1
Hmmm...
You need some wiring diagrams to see if it is a BCM programming issue.
Often, it is not just programming (e.g. to add cruise require new steering wheel, clock spring, and programming),
But the basic wiring is also different.
Exactly what are you trying to get working?
The wireless remote?
If so, that is a lot more work...
Old May 5, 2010 | 06:04 PM
rclarke's Avatar
rclarke
My 2003 E350 had power door locks but no remote control system. I added a Ford hang on keyless entry system. The hang on unit also had an alarm system as part of it. I didn't set up the alarm system but the keyless entry system works just like factory.
Old May 5, 2010 | 06:15 PM
gearloose1's Avatar
gearloose1
rclark
That sounds right, I have a 2004 that is virtually identical to yours and the OP 05.
There was a factory upgrade kit that let you do that.
Old May 6, 2010 | 12:31 AM
maples01's Avatar
maples01
Where is the keyless unit at, I'd like to see if my 99 has it, it's loaded with everything else?
Old May 6, 2010 | 07:30 PM
tk110's Avatar
tk110
I have a 1999 E450 with power locks that I would also like to add remote door locks on......
Old May 6, 2010 | 09:24 PM
andrewzx92000
Thanks for the input follks. today I went to Best Buy and bought an alarm that had the remote included. $200 and a long install. Apparently the van uses a 5 wire set up on the door locks where as a lot of newer vehicles have only a two wire. The remote works fine and they did a pretty tidy and nice install. Lifetime warranty on their workmanship and a year on the alarm.
I hated not putting Ford stuff on it but I'll wee how it goes.
Andrew.
Old May 6, 2010 | 10:21 PM
maples01's Avatar
maples01
I have a remote start that taps into the door locks, I've yet to finish the install.
Seahn
Feb 7, 2025 03:05 PM
theseus
Nov 11, 2017 09:31 AM
cecilt
Jan 30, 2017 05:45 PM
ligito
Oct 19, 2016 02:15 PM
dh_meyer
2009 - 2014 F150
Dec 15, 2015 11:44 AM
