Factory Tach question.
Old Jan 31, 2003 | 08:37 AM
Big Red's Avatar
Big Red
I wanted a factory tach for my '83 F100 so I have just purchased a factory gauge cluster with a tach from a 1983 Ford F series truck. It should arrive by mail in the next week or so.
My question is, can I install the whole gauge cluster in my dash? Will it plug into my existing wiring harness? Or do I have to remove the tach from the new cluster and install it into my existing dash. If so, how do I wire it up?
Would appreciate any help on this topic.
Cheers,
Big Red
Nova Scotia
Canada
Old Jan 31, 2003 | 10:20 AM
82F100SWB's Avatar
82F100SWB
Most likley the factory tach guage cluster has a speedometer with a trip meter, that makes it worth swapping in too...
It will be a plug and play operation if you have oil and amp gauges, if you have idiot lights, you'll have to start wiring.
If I can get my scanner up and running tonite, I'll scan in the wiring schematic...
BTW, I'm formerly from NS...
Evan
Old Jan 31, 2003 | 10:29 AM
Big Red's Avatar
Big Red
Evan,
That would be great... I have idiot lights in my dash now. I also have another dash unit with gauges but no tach. So, by combining the two I might make it work.
I would appreciate the wiring diagrams as a reference. Send them to me by email.
Where and when did you live in Nova Scotia?
Big Red
'83 F100 LWB 302 auto
Old Jan 31, 2003 | 11:52 AM
Mil1ion's Avatar
Mil1ion
If memory serves me correctly.
The gauges cluster takes a 18 pin connector and the idiot light cluster takes a 14 pin connector.
Good luck with this one.
Old Jan 31, 2003 | 01:11 PM
Franklin2's Avatar
Franklin2
If you do a search (which works good now by the way) in this forum, I seem to remember a guy wrote in on putting a jumper in somewhere to make the tach work for a six cylinder or a eight cylinder truck. He may be able to help with some of the other questions too if he is still around.
Old Jan 31, 2003 | 06:30 PM
Big Red's Avatar
Big Red
Well I did a search other posts for information and found lots but I have a few questions.
I have idiot lights instead of gauges and without taking my dash apart and refering to the Haynes manual, I should have the 14 pin conector on the dash plug...bummer. This means I can't plug in the cluster with the gauges and tach which needs the 18 pin plug. However, I think I can wire in the tach.
I see from previous posts that there are 4 posts on the back of the factory tach... here is where I think they go:
"G" > to ground
"B" > +12v supply for the light; wire to the dimmer switch
"C" > to the coil
Now the fourth post labeled "8" seems to be a mystery... where does it go?
Old Jan 31, 2003 | 07:41 PM
drade's Avatar
drade
Question Factory Tach question.
I may be an idiot for asking, but what are idiot lights?
Old Jan 31, 2003 | 08:10 PM
Big Red's Avatar
Big Red
Warning lights on your dash... i.e. Oil & Charge.
Old Jan 31, 2003 | 08:50 PM
steve83's Avatar
steve83
Originally posted by Big Red
"G" > to ground
"C" > to the coil
To a large degree, I don't think it matters. Your film circuit should already have the terminals for the tach and your wiring harness should have the wires. It's not the easiest thing, but it's also not very difficult to pull the cluster, disassemble it, remove the blank tach plate & speedo, and install the new speedo & tach from the other cluster. The hardest part will be getting the headlight & wiper ***** off. Just put your old parts back into the new cluster and you can sell it or keep it for a later rewiring project.
BTW, I think the 8 terminal goes to power on V-8 applications and ground on I-6s, but I'm not sure.
Old Feb 1, 2003 | 09:40 AM
82F100SWB's Avatar
82F100SWB
The 8 terminal is grounded on V8 applications, and left ungrounded on 6 cyl ones.
Steve: This is not so on the idiot light trucks, they have only a 14 pin instrument cluster connector, compared to the "standard" 18 pin one.
Big Red: as soon as I get my stupid scanner working, I will get the wiring diagrams scanned in for you.
If you want to get the guages installed and working, you will need a new plug for the cluster and a new oil pressure sending unit. There'll be a bit of wiring have to be done too, I did this swap once, but, it's been a while.
I just moved from NS last June, Lived in Antigonish for the last 4 years, and, in Cape Breton previous to that.
Evan
Old Feb 1, 2003 | 10:39 AM
Franklin2's Avatar
Franklin2
That "bit of re-wiring" would go all the way out to the alternator wouldn't it? The alternator is wired different for guages vs idiot lights.
Old Feb 3, 2003 | 10:26 PM
84ford's Avatar
84ford
I know when I tried to put a Tach in my 84 F150, it had the larger connector on it. I could not get it to work for the life of me. I finally traced everything back to not having a jumper (ground) wire that is located on the wiring harness behand the radio. I got the housing from a wrecked truck that has the connections for the dome light on the drivers side of the truck. I used the wires and ends from this pigtail (so to speak) to make a ground connection using factory plugs. It works great now. The connector that goes into the back of the cluster should work, but you should get the the connectors and run them as if you were hooking up an aftermarket tach. Just trace the cooper pathways back to where the plugs is placed into the cluster. If there are pins there it should not be much of a problem.
I hope I could help
Let me know how you make out.
Bob
Old Feb 23, 2003 | 12:37 PM
bignasty's Avatar
bignasty
sent that plug and a cd to you yesterday....hope it helps......
Pross78
New Member Introductions
May 22, 2013 01:13 PM
dmejack
Feb 22, 2011 04:16 PM
Big Red
Aug 24, 2005 09:51 PM
nsguy_2
Feb 1, 2005 10:52 AM
isac50
Dec 31, 2001 08:17 AM
