Crown Vic into a 63 Styleside - Steering Question
Old 02-21-2011, 05:24 PM
dmejack's Avatar
dmejack
dmejack is offline
I am relatively new to this forum and have been doing a lot of reading on the CV swap. I have a 1963 Ford F100 Styleside with a 59 box on it. The truck was bought by my father in 1965. It currently has a 223 with a 3 speed on the column.
My plans for this year are to install a front crossmember out of a 2005 CV that I was able to find. The plan right now is to use an 8.8 rear end out of a 1995 crown vic. I am also installing a 5.0 (302) EFI with an AOD transmission in it. I will be starting on this project soon.
My question is this: what steering column can be used in this that will work with the CV rack and pinion steering. I want to have something that has a column shifter for the automatic. I want to stay away from the square steering columns that the newer vehicles have. I would like to keep the ignition in the dash but it is not mandatory. Any help in this area would be greatly appreciated.
Also, does anyone know of a Canadian distributor for parts for my truck. I am located in Nova Scotia, Canada and bringing stuff across the border is quite pricey.
Old 02-21-2011, 05:31 PM
garbz2's Avatar
garbz2
garbz2 is offline
You will need to custom mount the column. You can use a aftermarket unit from places like Ididit.
It will need the dash pedal mount reworked and a restraint at the floorboard or firewall.
Garbz
Old 02-21-2011, 09:21 PM
dmejack's Avatar
dmejack
dmejack is offline
There must be a cheaper alternative than using one of those columns. There has to be columns out there that other people have used from other vehicles and fabricated them to fit.
Old 02-22-2011, 04:16 PM
oldfordcoupe's Avatar
oldfordcoupe
oldfordcoupe is offline
well i used the cv column adapted it to the bolt pattern on the inside. then a pedestal just past the firewall where it is braced real well on the frame works find right now but i have a top loader 4-spd for the tranny
MCD46
02-04-2014 06:11 PM
Pross78
New Member Introductions
05-22-2013 01:13 PM
TinyOne
06-22-2005 11:16 PM
3dr97150
Modular V8 (4.6L, 5.4L)
12-16-2004 08:13 PM
Big Red
02-23-2003 12:37 PM
Quick Reply: Crown Vic into a 63 Styleside - Steering Question
