Door panel question
Old May 4, 2010 | 11:48 AM
IsoGrifo's Avatar
IsoGrifo
Door panel question
So in my 92 the door pulls/armrest are completely destroyed, hanging on by the back 1/4 or so.
So my question is do I just replace the door panel or can I replace the door pull?
OR... Does the 93 style door panel fit? I notice the dash is the same and that the door panels look to be a better quality so I'm just wondering if it works?
EDIT: Just noticed that the panels have the little "Triangle" in the front for the mirrors... so maybe if you put the glass from that door and somehow attached those mirrors? or just modded the panels to remove them?
I think I'm just gonna have to pick some up from the local pick n pull and try it out...
Old May 4, 2010 | 02:56 PM
michigan66's Avatar
michigan66
Door panels from '89 through '92 are all the same; Rangers, Bronco II's and Explorer. Try broadening your search.
Old May 4, 2010 | 05:15 PM
IsoGrifo's Avatar
IsoGrifo
ya I know those are the same, I was just wondering if the newer ones worked...
Old May 4, 2010 | 07:51 PM
Rangerman Stan's Avatar
Rangerman Stan
Door panels on 93 & newer are way different than your 92.
Old May 6, 2010 | 01:40 AM
IsoGrifo's Avatar
IsoGrifo
i thought they might be but i've started to get into a lot of custom fab stuff, if I get a little extra cash I might just buy an extra 89-92 door and a 93^ panel and see what I could do with it, and if it turns out horrible I'll at least have the satisfaction of knowing I sought out to try it
