87 ranger
Old May 3, 2010 | 02:20 PM
adrianpartida's Avatar
adrianpartida
87 ranger
i have a problem my ford ranger wont start i dont know what the problem is i replaced the solenoid and the starter and nothing wont start the battery is charged does anyone have a pic of the solenoid maybe i put it on wrong or someting can someone help
Old May 4, 2010 | 01:45 AM
g_k50's Avatar
g_k50
Why did you replace the solenoid? What's the CID of your Ranger? Auto or manual? Does the starter turn at all? If the starter turns does it engage the ring gear and turn the motor? What else have you tried?
Old May 4, 2010 | 05:30 PM
adrianpartida
it said to replace it so i did cuz i put a new starter and its a manual and nothing works no clicking or nothing
Old May 4, 2010 | 05:45 PM
g_k50's Avatar
g_k50
Remove and correctly re-install the starter.
Old May 4, 2010 | 08:49 PM
87 XLT's Avatar
87 XLT
Make sure it's in neutral & then try this very simple little test.
Pull the connector with the rubber boot off of the starter relay & jump 12 volts to that pin.
Does it crank??
Old May 5, 2010 | 10:01 PM
adrianpartida
imma try tonite thanx for the info ill keep u updated
