A/C went a squealing..
Old May 3, 2010 | 09:57 AM
timbersteel's Avatar
timbersteel
2 days ago, I was running my truck, and started the A/C. abut 3 mins into letting it run, it starting making this terrible squealing noise, with smoke and then it quit when I shut the A/C back off. The one side of the A/C line was SUPER HOT to the touch(on the driver side near the top of the radiator).
After doing some much needed research here on FTE, I did what was suggested and check the Air gap. it's about .026 give or take some. I pulled the faceplate of the clutch and there is no shim's behind the faceplate. The clutch moves when the A/C is off and also when the truck isn't running. Not completely freely, but not seized either.
Is this going to involve a new compressor and complete discharge? The only thing I could find that even closely resembled a washer was a snap ring inside the compressor housing. The faceplate with the spring load shows some metal to metal wear. I'm no einstein when it comes to A/C on auto's, but my bet is is on a new compressor..
Any ideas would be appreciated. Thanks!
Old May 3, 2010 | 02:05 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The squealing was either the belt or the bearing on the compressor or the tensioner....Prob the tensioner.
Old May 3, 2010 | 03:37 PM
timbersteel
Tensioner is a year old, belt is 2 years old. The A/c isn't blowing very cold when at idle. After 2 attempts at running the A/C, only to have the Gawd-awful sound of screeeching and smoke, it would quit as long as I turned the A/C off. Could it really be the tensioner?
Old May 3, 2010 | 08:34 PM
lsrx101's Avatar
lsrx101
It could "could" be that your fan clutch is dead, causing the high side pressure to skyrocket and stall the compressor. I'm leaning toward a failing compressor, though
Run the AC and spray water from your garden hose over the condenser. If it operates correctly and cools well, the fan clutch is dead or the condenser/radiator is plugged with dirt and debris.
If it still locks up and squeals, the compressor is probably toast.
To know for 100% certain, you would need to monitor the High side pressure and see where it is when the compressor gets tight.
Old May 3, 2010 | 10:13 PM
timbersteel
I'm leaning towards a failing compressor. I no longer have a fan clutch installed. I removed the fan clutch and fan when I changed over to (2) 16" E-fans. I have checked the condenser and the the radiator. The radiator is 3 years old. I periodically check and clean the condenser and the rad.
I have a local mechanic here that stands by their work, and doesn't charge as much as the dealer does. I was leaning towards the thought of the compressor, so I will drop by tomorrow morning and give them the symptoms.
Old May 4, 2010 | 07:23 AM
MBDiagMan's Avatar
MBDiagMan
It is very simple to determine if the compressor is locked up or not. Simply grab the front most of the compressor in front of the belt and see if it turns freely. If it does, then the compressor is not locked up internally. I expect that it will feel like the compressor is full of rocks.
Jlag94
2009 - 2014 F150
Mar 14, 2017 06:57 AM
_red rocket_
6.7L Power Stroke Diesel
20
May 9, 2015 12:03 PM
dieselfumes12
Dec 18, 2012 07:52 PM
DavidS827
1997 - 2003 F150
16
Aug 27, 2012 02:54 PM
dugd111
Sep 17, 2009 09:02 PM
