Wiring help
Old May 2, 2010 | 10:52 PM
jgofff350's Avatar
jgofff350
Wiring help
I've got an '02 F350 7.3L that has an 'gremlin'. Have tried everything, then after reading a few threads on this website, decided to try to replace the valve cover gaskets and wires. Ordered the kit and have it now, but my problem is that the new wires that need to be spliced into my existing harness to not match in color. On the package, it lists the OE wire color that should correspond with the 6055192-A wire color...but the wiring harness I took off my truck has totally different colors. WHAT!!?? Is there a engine wiring diagram out there? I haven't been able to find it.
Thanks....need this truck fixed so I can haul my camper. Time to fish!
Old May 2, 2010 | 10:54 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Not sure, but I don't think I would use a kit that you need to splice in. Sorry, just my .02. Are you positive you recieved the correct kit?
Old May 2, 2010 | 11:10 PM
PaysonPSD's Avatar
PaysonPSD
Welcome to FTE.
What led you to believe you need to splice in new wires? Did you check to make sure the connectors under the VCs are tight?
Old May 2, 2010 | 11:28 PM
jgofff350's Avatar
jgofff350
Well... I got the valve cover gasket kit from Rockauto.com and it appeared to be the correct part for my truck. Part # 6055192-A. I did research it to make sure before I bought it and the connectors look the exact same as the ones in my truck now (long narrow oval shape that is blue, purple and black in color) The only difference are the wires coming OUT of the connectors that run to rest of the engine harness. What I have is the gasket itself AND the pigtails, so they need to spliced into my harness. I just don't know what colors go together.
Old May 2, 2010 | 11:42 PM
PaysonPSD's Avatar
PaysonPSD
Go to this LINK and use marshall as User ID and public as Password. On the page that comes up after you hit login click on Auto Repair Reference Center. Then just follow the menu for your truck.
Cbad285
Jan 13, 2016 03:03 PM
mrbdmorris
Dec 7, 2015 08:03 AM
mmasters27
Aug 15, 2014 11:58 AM
dosecobanya
1997 - 2003 F150
Aug 30, 2012 04:26 PM
muleguitar
26
Jan 4, 2010 10:05 PM
