engine fit
The 302 will require a bellhousing that bolts up to it and I don't believe they make one that will do that, and accept your clutch pedal arrangement.
Unless it's a light duty 3 speed and you can find an adaptor ring to replace the flywheel cover (with the 3 speeds, the "Bell Housing" was 2 pieces - one of which was cast into the trnasmission housing - called the clutch cover. The other half was the flywheel cover and bolted to the engine).
I could be wrong.
If you are going to install a 302, why not put it in with a modern transmission that bolts up to the 302?
Flat-o Products, Inc.
Otherwise check with Speedway Motors or Summit. If you don't find it online, make the phone call.
Somebody out there makes what you're looking for - I just can't find it at the moment.
If you're going to use the 302 and C4 you have to cut the factory cross member out and use a add on that connects top the tailshaft of the C4. You will also need to save the part of the cross member that the brake master cylinder is connected to.
I don't believe it is a lazy mans job. It does take planning and a lot of energy.
