engine fit
Old May 2, 2010 | 10:35 PM
lgwitt's Avatar
lgwitt
engine fit
I have a 51 f2 with the original bellhousing and transmission. How can i adapt a 1908 302 to this setup.
Thanks, Les
Old May 3, 2010 | 01:42 AM
Julies Cool F1's Avatar
Julies Cool F1
I don't think you can.
The 302 will require a bellhousing that bolts up to it and I don't believe they make one that will do that, and accept your clutch pedal arrangement.
Unless it's a light duty 3 speed and you can find an adaptor ring to replace the flywheel cover (with the 3 speeds, the "Bell Housing" was 2 pieces - one of which was cast into the trnasmission housing - called the clutch cover. The other half was the flywheel cover and bolted to the engine).
I could be wrong.
If you are going to install a 302, why not put it in with a modern transmission that bolts up to the 302?
Old May 3, 2010 | 09:01 AM
mtflat's Avatar
mtflat
Couple of options - you might check with Gene Benson at Flat-O products. He specializes in Flathead to C4's but an adapter can easily go the other way round.
Flat-o Products, Inc.
Otherwise check with Speedway Motors or Summit. If you don't find it online, make the phone call.
Somebody out there makes what you're looking for - I just can't find it at the moment.
Old May 3, 2010 | 10:59 AM
lgwitt's Avatar
lgwitt
transmission
I have the c4 that came with the engine. I am looking for the easiest way to do it. It has no engine but a tranny and i am lazy.
Old May 3, 2010 | 11:34 AM
vbarker's Avatar
vbarker
I didn't realize they made a 302 in 1908,,, LOL
If you're going to use the 302 and C4 you have to cut the factory cross member out and use a add on that connects top the tailshaft of the C4. You will also need to save the part of the cross member that the brake master cylinder is connected to.
I don't believe it is a lazy mans job. It does take planning and a lot of energy.
