Hey guys. I have a 2005 cc sb. My truck is dying when i'm coasting into a red light or a stop sign. It started doing it last week and only happened a couple times but now its getting more frequent. The truck will start up but now sometimes the truck won't start when warm. It will finally start on the 2nd or 3rd time. Any thoughts.
No codes what so ever. The truck didn't do it at all today. Just after it was warmed up it turned over for about 4 sec to start once.
I then hooked up to my trailor and put it tow-haul and the dash rang about 3 times going down the road. No lights lit up though on the dash just a ring noise. It happened Once about every five minutes. Something in the fuse panel you think? Its very odd.
I would suspect a hpop leak. How do you know there is no codes? Do you have a code reader? The reason I ask is because you can have a code with out a cel on.
I brought it in to the service shop and no codes. He even said that the Oil Pressure is right were it should be. I just got back home again and it quit twice on me. Stared right back up though. Its got me mind boggled
