piece of crap 2.9 pXXsing ne off
here s the problem, 87 ranger 2.9 4X4 auto,runs like crap when ever it feels like it. when problem occurs it shoots black smoke out tailpipe, going into a full rich condition, sometimes it'll do it at an idle for 30 seconds and then will fix it self. the injector pulse does change between when it is running good and bad so i know some thing is telling the computer to run rich at times.
parts tested or substituted with used or new include-
-computer, map sensor, coolant temp sensor, tps, oxygen sensor, ignition module, removed wiring harness from truck and checked for rubbed through wires, cleaned grounds, made sure rite starter solonoid was on truck, unplugged egr& exhaust pressure sensor,
- we are thinking along the lines now of a injector solenoid shorting out once in a while
we are hoping that the ignition switch starts on fire and burns the truck, then i don't gotta worry about it.
anybody got any clues to get this ranger back on the road
yea, we ran the truck with that vacuum line unhook and test drove it. it would still act up usually after 1/4 at 80 km but now it acts up sometimes in 50 feet or after a 10 mile run. the fuel pressure was about 35 40 psi i belive with the regulator unhooked. we are pretty sure it is a computer problem because of the way the injector pulse changes when the truck starts running bad, then all of a sudden changes the injector pattern and runs 100%. i think i've run out of options. i just wonder if an injector is shorting out and screwing up the computer
deere842
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
08-30-2015 11:54 PM
bluestreak1979
1983 - 2012 Ranger & B-Series
08-21-2006 08:48 PM
