Sponsored by: Auxito
starting probs
Old May 1, 2010 | 04:09 PM
slomafarms's Avatar
slomafarms
starting probs
im having problems with my 01 f150 5.4(114,000 mi) on startup. ill turn the key to start it and it cranks good but takes a few extra sec to start then normal. but sometimes it starts fine. if i try to start it and it doesnt fire right away and let off then try to start again it starts right up?? any suggestions??
Old May 1, 2010 | 04:18 PM
graythunder's Avatar
graythunder
Keep your injectors, air filter clean. At 114k it wouldn't "hurt" to swap plugs and plug wires.
Old May 1, 2010 | 06:17 PM
slomafarms's Avatar
slomafarms
i plan to do the plugs really soon but im gonna wait a bit because i just got it 2 weeks ago. air filter is clean i did that right after i got it home the day i picked it up. i put a shot of lucas in the gas last night. anything else you can think of that would be an issue? like i said theres times where it starts great and theres times where it does this
Old May 1, 2010 | 07:55 PM
graythunder
Get your injectors cleaned... gas additives are very ineffective. Lots of car/truck owners overlook that.
It could be your fuel system sensors need to be re-set or corrected... but I doubt it.
You ARE using 87 octane fuel, correct?
I am sure it is something minor. Look at the silly, cheap, obvious things first.
Old May 1, 2010 | 09:01 PM
Ron W.'s Avatar
Ron W.
Post
Originally Posted by slomafarms
im having problems with my 01 f150 5.4 if i try to start it and it doesnt fire right away and let off then try to start again it starts right up?
That is the part that peaked my interest, priming the fuel system more than once. Dirty fuel filter? weak fuel pump?
Old May 1, 2010 | 10:37 PM
slomafarms's Avatar
slomafarms
the previous owner put a new fuel pump on it.. so possibly the filter? today it started funny about 3-4 times but other than that it started like normal
Old May 2, 2010 | 03:05 AM
JJ98's Avatar
JJ98
could need a presser regulater my truck did that it had high miles replaced injecters and run great now
Old May 2, 2010 | 09:15 AM
slomafarms's Avatar
slomafarms
presser regulator???
Old May 3, 2010 | 08:47 AM
slomafarms's Avatar
slomafarms
yes im running 87 octane. what things should i look at besides the injectors? it runs strong too, doesnt idle rough or anything
Old May 3, 2010 | 08:56 AM
powersmoked's Avatar
powersmoked
I agree with the fuel pressure suggestions. change the fuel filter. check fuel pressure. I think it has an iacv i would pull that and clean it...check for codes also even if the lite is off......
Old May 3, 2010 | 10:42 AM
slomafarms's Avatar
slomafarms
iacv? never heard of it. there isnt a check engine light
Old May 3, 2010 | 10:50 AM
powersmoked
iacv=idle air control valve.......it is attache to the TB. I dont think it is the issue but it is a good maintenance to remove and clean out the chanber. ( if you are in to woodworking at all it looks like a 4" long Biscuit joiner).
Old May 3, 2010 | 11:17 AM
slomafarms's Avatar
slomafarms
now i know what your talking about...i just didnt know the abbreviation. so would injectors do this? considering it only starts funny 2-4 times per day opposed to all the time
Old May 3, 2010 | 11:30 AM
powersmoked
it could be the injectors but I am going to guess that is not the issue. If it was my truck i would do a tunup, including plugs, pcv, airfilter, clean maf, clean iacv, change fuel filte, add some injector cleaner. . if the issue is still there I would suspect the fuel delivery system. I would do a presure test, check for codes...... if you csn buy a cheap code reader for $20 bucks because sometimes the codes are pending and then go away before the light comes on. but if you check especially when it is acting up you might catch a code........
Old May 3, 2010 | 12:21 PM
slomafarms's Avatar
slomafarms
i actually just got the truck 2 weeks ago and im waiting on the bank to finish up a few things..thats why i havent done a complete tuneup yet but trust me i plan to...previous owner said he hadn't done spark plugs in it so im thinking this could be one of the issues. but he did change the fuel pump..ive been using lucas in the fuel too
